Use cast.show_lovelace_view in script
I am trying to use the feature for casting in a scipt, but recieve an error.
script:
‘1580725287208’:
alias: test
sequence:
  • data:
    view_path: Hub
    entity_id: media_player.hub
    service: cast.show_lovelace_view
this works fine when calling by hand from devtools - services, but gives an error from calling the script.
error:
Kan service script/1580725287208 niet aanroepen value should be a string for dictionary value @ data[‘entity_id’]
Any help?
Michael
adjust your spacing. See link for example.
Along with what silvrr said, please format your code properly. Otherwise we can’t see these spacing issues.
Use three backticks (```) above and below your code.
‘1580725287208’:
  alias: test
  sequence:
  - data:
      view_path: Hub
  alias: test
  sequence:
    - service: cast.show_lovelace_view
        view_path: Hub
