Use CYD touchscreen to toggle a boolean
I started off with getting CYD code to work from here, with tweaks to meet my hardware
I want to use the “Button A” to toggle a boolean and make the screen change based on that boolean.
I create a boolean in GLOBAL.
globals:
  - id: bool_A
    type: bool
    initial_value: 'false'  #bool_A set to false
    restore_value: no # Optional: defaults to no
Further down, I add a toggle in BINARY_SWITCH
binary_sensor:
  - platform: touchscreen
    x_min: 20
    x_max: 140
    y_min: 60
    y_max: 180
    on_press:
      then:
        - homeassistant.service:
            service: bool_A.toggle   #bool_A is toggled if Button A touched
    x_min: 180
    x_max: 300
    y_min: 60
    y_max: 180
And on my display, I create an IF statement
display:
  - platform: ili9xxx
    model: ILI9341 #st7789v
  #EXTRA CODE REMOVED FOR BREVITY
    lambda: |-  #if bool_A then fill rectangle. Else just outline
      it.fill(id(Color::BLACK));
      if (bool_A) {
        it.filled_rectangle(20, 60, 120, 120, id(ha_blue));
      } else {
        it.rectangle(20, 60, 120, 120, id(ha_blue));
      it.rectangle(180, 60, 120, 120, id(ha_blue));
      it.print(80, 120, id(arimo96), TextAlign::CENTER, "A");
      it.print(240, 120, id(arimo96), TextAlign::CENTER, "B");
No matter how many times I touch the Button A, the rectangle is always filled ? Why? What triggered bool_A to be true? Why is it always true?
Just in case, here is my full code below
esphome:
  friendly_name: AliExp-CYD
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "I have more than 1 device"
ota:
  - platform: esphome
    password: "I am not smart enough to add multiple"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Aliexp-Cyd Fallback Hotspot"
    password: "secrets in the secrets.yaml file"
captive_portal:
globals:
  - id: bool_A
    type: bool
# ESPHome Display related setup
# Create a font to use, add and remove glyphs as needed.
font:
  - file: 'fonts/Arimo-Regular.ttf'
    glyphs: "AB"
# Create a Home Assistant blue color
color:
  - id: ha_blue
    hex: 51c0f2
# Home Assistant related setup
light:
  - platform: monochromatic
    output: backlight_pwm
    name: Display Backlight
    restore_mode: ALWAYS_ON
# Setup two binary sensors for the two areas for touch
binary_sensor:
    x_min: 20
    x_max: 140
    y_min: 60
    y_max: 180
    on_press:
      then:
    x_min: 180
    x_max: 300
    y_min: 60
    y_max: 180
# Hardware related setup
# Setup SPI for the display. The ESP32-2432S028R uses separate SPI buses for display and touch
spi:
  - id: spi_tft
    clk_pin: GPIO14
    mosi_pin: GPIO13
    miso_pin: GPIO12
    interface: spi2
  - id: spi_touch
    clk_pin: GPIO25
    mosi_pin: GPIO32
    miso_pin: GPIO39
    interface: spi3
# Setup a pin to control the backlight
output:
  - platform: ledc
    pin: GPIO21
# Setup the ili9xxx platform
# Display is used as 240x320 by default so we rotate it to 90°
# We print date and time wth the strftime() function, see the ESPHome documentation to
# format date and atime to your locale.
display:
  - platform: ili9xxx
    model: ILI9341
    spi_id: spi_tft
    cs_pin: GPIO15
    dc_pin: GPIO2
    invert_colors: false
    spi_mode: MODE3
    data_rate: 40MHz
    # data_rate: 2MHz
    # pixel_mode: 16bit
    color_order: bgr
    color_palette: 8BIT
    # update_interval: 1000ms
    # auto_clear_enabled: true
    dimensions:
      height: 240
      width: 320
      offset_height: 0
      offset_width: 0
    transform:
      swap_xy: true
      mirror_x: false       #true false
    # show_test_card: true
      if (bool_A) {
      } else {
# Set up the xpt2046 touch platform
touchscreen:
  platform: xpt2046
  spi_id: spi_touch
  cs_pin: GPIO33
  interrupt_pin: GPIO36
  data_rate: 2MHz
  spi_mode: MODE0
  threshold: 400
  update_interval: 50ms
  transform:
    swap_xy: true
    mirror_x: false
    mirror_y: false
  calibration:
    x_min: 390
    x_max: 3800
    y_min: 210
    y_max: 3800
This would try and execute an action on the Home Assistant platform. If you want to toggle a boolean you have defined as a global in ESPHome:
    on_press:
      then:
        - lambda: |-
            id(bool_A) = !id(bool_A);
I appreciate the response. At first, the code acted the same, then I updated my IF statemnet inside the display code further down to match your code “(bool_A)” → “(id(bool_A))” and now it works. THANK YOU so much !!
Working display code
display:
  - platform: ili9xxx
      if (id(bool_A)) {
      } else {
