Use entity state in glance card title
I am trying to setup a glance card with a dynamic title which would reflect state of an entity.
The entity is input_select.status and can have Values Normal or Away.
I would like the Card title to be. Home Status : Away
The code below is not getting me anywhere
  - type: glance
    title: $('home status' + {{'state.input_select.status'}} )
    show_name: true
    show_state: false
    columns: 6
    entities:
      - entity: input_select.status
        icon: mdi:car
        tap_action:
          action: call-service
          service: script.set_normal_mode
        tap_action:
          service: script.set_away_mode
You’re going to need a custom card (card-modder): https://github.com/thomasloven/lovelace-card-modder#templates
Not sure if this applies to the title but see no reason why it shouldn’t.
The custom template card might do it too.
Did you ever find a solution?
Here is what I did for mine - but would love to have the title say what is currently set.
type: entity-filter
card:
  type: glance
  title: Presence
  show_state: false
entities:
- type: entity-button
  name: "Set to home"
  icon: mdi:home-account
  entity: script.home
  tap_action:
    service: script.turn_on
    service_data:
      entity_id: script.home
  name: "Set to night"
  icon: mdi:weather-night
  entity: script.night
  tap_action:
    service_data:
      entity_id: script.night
  name: "Set to away"
  icon: mdi:car
  entity: script.away
  tap_action:
    service_data:
      entity_id: script.away
state_filter:
- "off"
Then, the scripts look like this:
home:
  alias: Home
  sequence:
  - service: switch.turn_off
    entity_id: switch.syno_mode
  - service: rest_command.set_vera_home
  - delay: '00:01:00'
  - wait_template: "{{ not is_state('sensor.vera_mode', '1') }}"
away:
  alias: Away
  sequence:
  - service: light.turn_off
    entity_id:
    - light.b_hue_counter
    - light.b_hue_trophy
    - light.k_hue_sink
  - service: rest_command.set_vera_away
  - delay: '00:05:00'
  - service: switch.turn_on
  - wait_template: "{{ not is_state('sensor.vera_mode', '2') }}"
night:
  alias: Night
  sequence:
    entity_id:
    - light.k_hue_sink
  - service: rest_command.set_vera_night
  - delay: '00:05:00'
  - wait_template: "{{ not is_state('sensor.vera_mode', '3') }}"
While a bit convoluted (and only viable for smaller things) it could be done without a script by using Conditional cards.
By smaller things I mean, stuff where you don’t need the exact state value, but rather want to display something based on that value. Example: If state = away display Card with title ‘Status: Away’ and hide the others.
Here’s 3 buttons, the middle button changes title (and what it does) based on vacuum’s state. It should give you a rough idea.
cards:
  - entity: vacuum.xiaomi_vacuum_cleaner
    show_icon: true
    show_name: true
    tap_action:
      service: vacuum.clean_spot
    type: entity-button
  - card:
      show_icon: true
      show_name: true
      tap_action:
        service: vacuum.start
      type: entity-button
    conditions:
        state_not: cleaning
        state_not: docked
        state_not: error
        state_not: returning
    type: conditional
  - card:
      show_icon: true
      show_name: true
      tap_action:
        service: vacuum.pause
      type: entity-button
    conditions:
        state_not: paused
        state_not: docked
        state_not: idle
        state_not: error
    type: conditional
  - card:
      show_icon: true
      show_name: false
      tap_action:
        action: null
      type: entity-button
    conditions:
        state_not: cleaning
        state_not: paused
        state_not: idle
    type: conditional
    show_icon: true
    show_name: true
    tap_action:
      service: vacuum.return_to_base
    type: entity-button
type: horizontal-stack
