Hello everybody
I’m trying to write an automation to switch on the air conditioners dynamically based on presence in the rooms and how much my solar system produces.
the second part works already give time, now I wanted to add the part of the rooms.
I am trying to use a for loop inside an entry but I am constantly getting errors.
the problem appears on the “set”.
you can use a for loop inside an automation.
if you have any advice?
this is the code
alias: Autoaccensione condizionatori NEW
description: ''
- platform: numeric_state
entity_id: sensor.grind_power_now
below: '100'
for: 00:20:00
- platform: time_pattern
minutes: /20
condition:
- condition: numeric_state
entity_id: sensor.produzione_istantanea_fotovoltaico
above: '500'
- condition: time
after: '10:30'
{% set sorted_list = group.usostanze | expand | sort(attribute='state', reverse=true)%}
{for state in sorted_list %}
{% set nome = state.entity_id.split("uso_")[1] %}
{% set valoremax = "sensor.max_consumoclima"+nome %}
{% set valoretemp = "sensor."+nome+"_room_temperature" %}
{% set valoreentity = "climate."+nome %}
- condition: template
value_template: {{((states.sensor.produzione_istantanea_fotovoltaico.state)|float - (states.sensor.assorbimento_istantaneo_casa.state)|float - (states(valoremax))|float) >= (states.input_number.delta_fotovoltaico.state) |float }}
- condition: state
entity_id: {{valoreentity}}
state: 'off'
for: '00:15:00'
value_template: {{((states(valoretemp)) > states.input_number.temperatura_interna_max.state) or ((states(valoretemp)) < states.input_number.temperatura_interna_min.state) }}
- service: climate.turn_on
data: {}
- condition: state
entity_id: automation.spegnimentoautomaticocondizionatori
state: 'off'
- service: automation.turn_on
data: {}
- service: tts.google_translate_say
entity_id: media_player.gruppo_casa
message: avviato servizio di climatizzazione
{%- endfor -%}
mode: single
