Hey there!
I have a large PV-setup with SMA hardware as well as a small setup on the garage using a Fritz!Dect 210 connected to a micro inverter. The 210 tracks the generation as consumption as it doesn’t support PV generation on its own. That was okay for me as I just had to revert the information presented in my mind.
Is it somehow possible to use the Fritz!SmartHome integration to “correctly” interpret the values provided by the 210?
Something like implementing a switch within Home Assistant that makes it possible to define that outlet as generator instead of consumer.
Thanks!
