Use Google Calendar Event message data as variable in service call
Hello there,
I am quite new to Home Assistant and have been reading in this forum and also searching Google like crazy in order to accomplish what I want, yet I lack the understanding to do so.
Following situation:
I have a Shelly 2.5 in order to control my roller shutter.
I want to create an automation that reads an event from my Google calendar, extracts numerical data (percentage) from the title and uses this data to control the roller shutter.
So far, I am able to create events called “#WZK” and once they occur, the roller shutter moves to a predefined position (e.g. 90% in the example below).
However, I want to be able to create events with the pattern “#WZK 72” in order to move the roller shutter to 72% once the event occurs.
Here are the excerpts from my configuration files:
configuration.yaml
rest_command:
  shelly_wzk:
    url: "http://192.168.178.30/roller/0?go=to_pos&roller_pos={{ poswzk }}"
google_calendars.yaml
- cal_id: ********@group.calendar.google.com
  entities:
  - device_id: hagc
    ignore_availability: true
    search: "#WZK"
    name: Home Assistant Google Calendar
    track: true
automations.yaml
- id: '1589283711147'
  alias: TestWZK
  description: ''
  - entity_id: calendar.hagc
    platform: state
    to: 'on'
  condition:
  - condition: template
    value_template: '{{is_state_attr(''calendar.hagc'', ''message'', ''#WZK'') }}'
  - alias: ''
      poswzk: 90
    service: rest_command.shelly_wzk
I already tried to adapt the action to the following:
  - alias: ''
    data_template:
      poswzk: '{{state_attr(''calendar.hagc'', ''message'')}}'
and change the search term in google_calendars.yaml to "#WZK ".
From the Google Calendar Event documentation I understood that the search term will be excluded from the message attribute. However, when I take a look at the state of calendar.hagc, the message always is “#WZK 72” but never “72”.
What am I doing wrong here?
Not sure I totally understand but if your message is “#WZK 72” and you only want the “72” why not do the following and call it good?
  - alias: ''
    data_template:
      poswzk: '{{state_attr(''calendar.hagc'', ''message'').split()[1]}}'
When I use your approach, the automation does not trigger automatically. But weirdly enough, when I trigger it manually, it works and takes the value from the calendar’s event title as wished.
EDIT:
It is working now. I had to remove the
 condition:
Thank you so much for your help! :slight_smile:
