Use it! Doc in the Getting Started Guide section
Hi there!
Quick question. I was checking the documentation and I found this: https://home-assistant.io/getting-started/use/.
Little bit lost because I use Docker and not Hassbian. Is this something Hassbian only? or am I missing a menu somewhere?
thanks!
Not sure specifically what you’re having trouble with, but that page does look half-done.
To access the UI of Home Assistant after installation, go to port 8123 of your device.
http://192.168.x.x:8123
you’re right, sorry. I was referring to the part:
To reload your configuration, go to Configuration in your side panel, and choose “CHECK CONFIG” and “RELOAD CORE”:
Can’t find any of this in HA and was wondering if is something just for Hassbian or spread in other installation methods.
To get the configuration panel, you need to add this to your configuration
config:
be careful while using with panel_iframe: or panel_custom: , e.g;
config:
panel_iframe:
  config:
    title: 'Ayarlar (panel_iframe)'
    url: 'http://192.168.1.2:7777/test.html'
    icon: mdi:settings
this is a wrong example about conflict. config: name should be unique in configuration while using with custom panels.
got it … thank you all! :slight_smile:
