I’m currently switching from a Fibaro HC2 to HomeAssistant.
I’m currently in the process of migrating the first components and am trying to program a NodOn wall switch in my home automation system using the Z-wave JS UI.
Unfortunately, my home automation system isn’t recognizing the remote during the program, and now I’d like to know if it’s even compatible.
The device is not listed in the z-wave js database https://devices.zwave-js.io/. This means when you add the device in Z-Wave JS UI it will show as unknown device
. Just because the device shows as unknown doesn’t mean its not compatible. You should have full functionality. The only thing that may not show up are the configuration settings which you can find here https://manuals.zwave.eu/backend/make.php?lang=EN&sku=CWS-3-1-0X&cert=ZC10-15070008.
Thanks for the device list and the instructions for the Nodon.
Interestingly, the procedure for including the remote control in the instructions you linked to me was DIFFERENT than in my manual!!
I’ve now managed to program the remote control, great!
