Use of state friendly name in template
Hello, sorry for probably a stupid question, but I must be missing something elemental…
How do I access state in template using friendly name ?
I have a sensor, shown in states as “sensor.0x00124b00239ddd94_humidity” entity, with friendly_name “cidl_sklep_humidity”.
I need to access it in template, trying it using the Template editor. It works ok this way:
{{ states("sensor.0x00124b00239ddd94_humidity") }}
results in some (expected) value:
58.2
But if try it using friendly name:
{{ states("cidl_sklep_humidity") }}
I get:
unknown
Thanks for help…
is a state attribute of your sensor; if you want to access this:
{{ state_attr('sensor.0x00124b00239ddd94_humidity', 'friendly_name') }}
Yes, that works, but that is not what I wanted to achieve. My concern was how to get the value while using just the friendly name, without using the “sensor.0x00124b00239ddd94_humidity” entity name (which could change if I e.g. replace the sensor, but keep using the same friendly name, I guess…)
This is not supported, you must use the entity id.
Sure but you can make the new entity_id match the old easily in one place (configuration/entities page). What you cant do (easily) is change the device_id. So avoid device automations and you will be fine.
I see, thanks for info.
