Use only positive value
I have a sensor that gives me positive value one discharging from my battery and negative value when charging it.
I would like to use only positive value in order to implement in the new Energy management system.
thanks
{{ state('something') | abs}}
Should give you positive values, but not sure that is what you are actually asking about.
Thanks hellis, i thinks that abs will give me the absolute value of a number, so if i have a negative value i would convert in positive one.
That is correct.
Your question is not explaining what you actually want so it’s hard to help you.
i try to explain better.
I have a sensor that can give me positive and negative value, i would like to create a sensor template that will consider only the positive values.
{% if states('something') | float >= 0 }
{{ states('something') }}
{% endif %}
could you put all the syntax?
the name of my sensor is : sensor.batteria_storage_power
Hi, did you solve this? How does your Sensor look like?
This is an example of my mqtt sensor working, I hope it helps you.
mqtt:
      - unique_id: freedsgrid
        state_topic: "freeds_1ec8/wgrid"
        value_template: >
            {% if value | float <= 0 %}
            {{ value | multiply (-1) }}
            {% else %}
            {{ '0' }}
            {% endif %}
        unit_of_measurement: "W"
maybe “else” is not necessary but it works fine
