I simply can’t find a way to lay hand on the values from the TRV’s own temperature sensor and the target temperature that es set on the TRV. I’d like to use both in automations. Most importantly I’d like to have the target temperature.
Please, if anyone could point out, what I am missing?
Those are both attributes of the climate entity’s state object.
What do you mean by “lay hand on” the values?
For use in automations, the general answer is “use templates”, but attributes can be accessed in State triggers and conditions… we will need a specific question if you want a specific answer.
There are a number of existing climate blueprints that may already do what you want to do, or you can use their configurations as inspiration and guidance for your automation.
