Use Rest Sensor with new Auth System
I have been using a rest sensor to access a pi zero which is outside to connect to my miflora sensors.
  - platform: rest
    resource: http://10.0.20.5:8123/api/states/sensor.bougainvillea_conductivity
    name: Bougainvillea Conductivity
    value_template: '{{ value_json.state }}'
    unit_of_measurement: "µS/cm"
Can someone help me with an example of how to access this sensor using the new auth system.
I managed to just use the legacy_api to get this up and running.
Can you pls share the new rest sensor code. I can’t find how to use the legacy_api in this case.
What version of HA are you using?
In any case you can enable legacy_api in the configuration.yaml like so
api:
  api_password: !secret api_password
my full config is located here Github
wow, you’re fast :slight_smile:
I’m using hass.io on both HA instances. I’ll checkout your config.
Thanks!
Still no success I’m afraid.
Getting error on hass.io system that should provide the data:
Login attempt or request with invalid authentication from xxx.xxx.x.xx
On the hass.io system requesting the data I have enabled api.
On the hass.io system providing the data I have enabled api and http, both with the same password.
Template code:
  - platform: rest
    resource: http://yyyy.yyy.y.yy:8123/api/states/sensor.miflora1_moisture
    unit_of_measurement: "%"
Can you help me?
Solved!
Adding trusted networks helped out…
I missed your previous post apologies, glad you got it sorted now you can deploy Pi zero minions all over your place :+1:
