Hello everyone,
For this specific usecase I would like to turn on the music on a Sonos speaker when a Hue lightstrip has a certain RGB Color. I’ve setup the following automation:
alias: WERKPLEK_Dirk - Speel muziek bij inschakelen 'Werken' scene
description:
triggers:
- trigger: template
value_template: >-
RGB Color:{{ state_attr('light.hue_bulb_bureau_dirk','rgb_color') ==
(255,214, 181) }}
enabled: true
conditions:
- condition: state
entity_id: input_boolean.kill_switch
state: "off"
actions:
- action: media_player.media_play
entity_id: media_player.sonos_symfonisk_slaapkamer
data: {}
mode: single
The problem is that the trigger isn’t activated when the light is set to RGB color 255,214, 181. I’ve tested the template code in Developer tools > Template and over there I see a change from ‘false’ to ‘true’. Any Idea why this automation isn’t triggered?
Nick4
(Nick)
January 22, 2025, 10:28am
2
Hi Dirk, did you check the automation traces?
Pretty sure the rgb_color
attribute would be a list
, but you are comparing it against a tuple
. Change the parenthesized value (255,214,181)
to one that is bracketed [255,214,181]
Also why do you have a “RGB Color:” prefix in your template? For a trigger template to work properly it must only result in a value which when returned to HASS can be interpreted as a boolean, which it never will with that prefix included.
Hellis81
(Hellis81)
January 22, 2025, 10:41am
4
If all else fails then this should work:
{{ (state_attr('light.hue_bulb_bureau_dirk', 'rgb_color') |list)[0] == 255 and (state_attr('light.hue_bulb_bureau_dirk', 'rgb_color') |list)[1] == 214 and (state_attr('light.hue_bulb_bureau_dirk', 'rgb_color') |list)[2] == 181 }}
Actually… this works.
{{ (state_attr('light.hue_bulb_bureau_dirk', 'rgb_color') |list) == [255,214,181]}}
meaning:
triggers:
- trigger: template
value_template: >-
enabled: true
Hello @Hellis81 ,
Thank you for your input. Thanks to that, I’ve adjusted my YAML code:
description:
triggers:
- trigger: template
value_template: >-
[255,214,181]}}
enabled: true
conditions:
- condition: state
state: "off"
actions:
data: {}
mode: single
When I set the lightstrip to RGB 255,214,181, the automation doesn’t get triggered.
This is what I see in the Developer tools > States when I filter on light.hue_bulb_bureau_dirk:
min_color_temp_kelvin: 2000
max_color_temp_kelvin: 6535
min_mireds: 153
max_mireds: 500
effect_list: None, candle, fire, prism, sparkle, opal, glisten, unknown, unknown, unknown, unknown, sunrise, sunset
supported_color_modes: color_temp, xy
effect: None
color_mode: color_temp
brightness: 206
color_temp_kelvin: 4347
color_temp: 230
hs_color: 26.722, 28.925
rgb_color: 255, 214, 181
xy_color: 0.401, 0.359
mode: normal
dynamics: none
icon: hue:bulb-classic
friendly_name: Bureau Dirk
supported_features: 44
Any idea what there is still wrong with the template trigger?
Hellis81
(Hellis81)
January 22, 2025, 8:41pm
6
Are you sure it’s not the condition that blocks it?
Is a trace created?
Or
What if you make a state trigger on attribute RGB color and use this template as the condition?
123
(Taras)
January 22, 2025, 8:44pm
7
description:
triggers:
- trigger: template
value_template: >-
{{ is_state_attr('light.hue_bulb_bureau_dirk', 'rgb_color', (255,214,181)) }}
enabled: true
conditions:
- condition: state
state: "off"
actions:
data: {}
mode: single
Thanks everybody, I’ve found the solution; remove the “RGB:” like @Mayhem_SWE suggested.
So this YAML code is working now:
description:
triggers:
- trigger: template
value_template: >-
{{ state_attr('light.hue_bulb_bureau_dirk','rgb_color') ==(255,214, 181)
enabled: true
conditions:
- condition: state
state: "off"
actions:
data: {}
mode: single
Hellis81
(Hellis81)
January 22, 2025, 8:56pm
9
My trigger did not have that.
That’s right, but the |list
and []
in your trigger shouldn’t be used. At least; I didn’t work for me.
