Use Tradfri Brightness to trigger switch
I have some tradfri bulbs, and also an LED light which can be dimmed.
I have the LED light in homeassistant OK, and I can use a switch on the dashboard to dim it.
What I’d like to do is when I dim the tradfri lights to 20%, I want that to trigger the switch to dim the LED light.
I can’t work out how to do the automation!
Use the numeric_state trigger with the attribute property (brightness is an attribute of the light) and it should trigger below 20.
Thanks. I can’t get it to work, do you put it in automations.yaml? I put the following in and the config errors with
Invalid config for [automation]: [attribute] is an invalid option for [automation]. Check: automation->trigger->0->attribute. (See /config/configuration.yaml, line 13).
    platform: numeric_state
    entity_id: light.tradfri_bulb_15
    # Optional
    # At least one of the following required
    below: 30
    # If given, will trigger when the value of the given attribute for the given entity changes
    attribute: brightness
    # If given, will trigger when the condition has been true for X time; you can also use days and milliseconds.
  - data: {}
    entity_id: switch.strip
    service: switch.turn_on
You are missing an alias for the automation, try like this:
- alias: turn light strip on when brightness below 30
    below: 30
  - entity_id: switch.strip
Thanks, I’m still getting the error about attribute being an invalid option.
I’m on v 0.114.1, does that make a difference?
Yes, this feature was introduced in 0.115. Before 0.115 you have to create a template trigger.
Thanks, I updated to 0.117 and got it working. Really appreciate your help.
