I was only able to do this because I did something in the first day or two of poking aound with mushroom cards and HA automatically defined and reused a variable in the YAML. Of course, it wasn’t what I wanted to do, and I immediately overwrote the YAML to do what I really wanted. I was lucky that I saved that really weird snippet of code just in case.
My “accidental” discovery of variables happened the same way that my code shows the “|2-” text in a couple of places. For the life of me, I haven’t figured out why it’s there and what it means differently than the other multiline indicators in yaml. But Homeassistant keeps putting it there if I use the graphical editor.
Mainly to see if/how I could do it, I have created a page in my dashboard to help me navigate through all the custom ESP devices I’ve created in my setup. Of course, it’s nice to be able to reset a specific device remotely, but it isn’t useful to have that button on every single dashboard. Every once in a while, I want to be able to access some of the more esoteric entities presented by a device, but don’t want to try and organize all of those very rarely accessed entities in a dashboard, or parse through the default dashboard, which has just become a ridiculously tedious sea of entities. Part of my goal is to eventually have HA spawn the web page hosted by an individual device if I click on the IP address or hostname chip. Unfortunately, so far I haven’t been able to pass the proper URLs via sensor or variable to the tap_action >> URL action path - it is a missing capability of the chip card. The only way the tap_action works is if I fully hardcode the URL, http://<ip address>
or http://<hostname>.local
- Of course, that defeats the whole idea of using variables and entities…
This is the diagnostic section I made for a Sonoff outlet. I am in the process of doing this for all the devices in my HA installation. Since the code I uploaded to the outlet maxxed out the storage space on the outlet, not everything can be managed by the device itself. The outlet itself doesn’t have the code storage available to store the IP address, SSID it’s connected to, the hostname or the device name as set in HA. Other devices are able to hold that information in text entities or text_sensors, but that only gets me 80% of the way.
You have to define the variable as part of an “entities” card “at the same level” that it will be used. This type of card (so far as I’ve used them) doesn’t show any content, except that they do occupy a little space, creating a bit of a gap at the left of the row, but allows you to create a variable that can be used later. I haven’t found any way to make them not take up that space - the visibility parameter might be a way, but it hasn’t bothered me enough to tackle it yet. Since I use the values within a grid card, I define the variables first and then the individual chips that use those variables.
Here’s the code for this diagnostic bit:
- square: false
type: grid
columns: 1
title: ''
grid_options:
columns: full
cards:
primary: Garage Spider Restart
secondary: |2-
{% if is_state ('switch.spider_one_restart', 'unavailable') %}Restarting...
{% else %}Double Click
{% endif %}
icon: mdi:radioactive
icon_color: |2-
{% if is_state ('switch.spider_one_restart', 'unavailable') %}pink
{% else %}lime
{% endif %}
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: perform-action
perform_action: switch.turn_on
entity_id: switch.spider_one_restart
- square: false
type: grid
columns: 1
grid_options:
columns: full
cards:
- type: custom:mushroom-chips-card
chips:
- type: entities
entities:
# These are dynamic on most of my custom ESP32 devices, but not on the Sonoff
# outlet due to code space constraints
- entity: sensor.spider_one_wattage
name: &ip1 "192.168.0.145"
# If the device has an IP Address sensor, it can be used to dynamically provide
# the value, such as
#name: &ip1 {{ states('sensor.spider_one_ip_addr') }}
name: &ipurl1 "http://192.168.0.145"
#name: &ipurl1 "http://{{ states('sensor.spider_one_ip_addr') }}"
name: &host1 "spider1"
name: &hosturl1 "http://spider1.local"
- type: entity
icon_color: amber
icon: mdi:gauge
- type: template
content: *ip1
tap_action:
action: url
url_path: *ipurl1
icon_color: teal
icon: mdi:ip-network
- type: template
content: Chameleon.M
icon_color: teal
icon: mdi:wifi-settings
- type: entity
entity: sensor.spider_one_wifi_signal
icon_color: teal
icon: mdi:wifi-check
- type: template
content: *host1
entity: text.garage_sensors_hostname
icon_color: purple
icon: mdi:sign-real-estate
hold_action:
action: url
url_path: *hosturl1
- type: template
content: Garage Spider
entity: text.garage_sensors_devname
icon_color: purple
When you define the variables, you HAVE TO use an entity that exists. The entity that you choose doesn’t have to be related to the variable at all, but it has to exist within the HA environment. You can use the same entity over and over again, and use a different name (create a new variable) each time. I randomly chose one that is an entity of the device I’m referring to, so that if a different device goes down, this diagnostic isn’t impacted.
I’m planning on trying out the decluttering card to make this way more efficient, but haven’t had the time yet. The decluttering card might solve a couple of problems I’ve run into, most specifically that neither of the URL actions work reliably, since they don’t properly parse the URLs if they’re pulled from entities and don’t seem to parse out any jinja.
You should be able to define &total and &ein just before the first line of the code you showed in the question. Create an entities type card, and then define an entity for each. Since it’s already part of what you’re presenting, just use sensor.sommerzeit as the entity and then define the value of each as needed. I’m sorry - I’m a bit too tired to parse out exactly how to translate exactly how to assign the proper value to your variables…I hope this pushes you in the right direction, though.
