Use weather temp to turn a tuya plus on
New here, set up HA last week and enjoying its features.
But i am having some issues with a certain automation.
I want my tuya plug (connected to a heater) to turn on for 5 minutes if the temp drops below 7 Celsius.
I have this is the YAML
platform: numeric_state
entity_id: weather.home
attribute: temperature
above: ‘1’
below: ‘7’
for: ‘5:00’
It randomly triggers but never consistent.
Would appreciate any help, thanks.
do you not want it to turn on at 1 or less?
Is this YAML from your automatons.yaml ?
The easiest way is for this to be two separate automations.
Turn on when below 7.
Turn off when state on for 00:05:00 (hour, minute, second…must include zeros for blanks)
Thanks for reply.
I’d like it to come on anything below 7
Yes that’s my yaml, I think it’s checking weather hourly hence why this only works periodically
I assume this anyway.
It should look like this: (use the </> above)
alias: Weather Test
description: ''
  - platform: numeric_state
    below: '7'
    for: '00:05:00'
condition: []
  - type: turn_off
    device_id: xxxxxxxxxxxxxxxxxxxxxxxx
    entity_id: switch.shelly_shsw_pm_bxxxxx
    domain: switch
mode: single
Thanks seems making them into 2 automations fixed the issue.
Working great now!
