I have Ollama with llama 3.2 and llava LLM up and running.VisonLLM, wyoming piper and whisper are also working in HA (but offloaded to external server). everything works fine. TTS/STT, also vision works fine and can tell me what it sees in a video stream. I am using a wyoming satellite for TTS an SST. I want to ask " what is happening around the house" and I want the response to come from the wyoming sattelite. But for the love of all. I cannot get it to work: This is my latest script. The main issue seems to be that the satellite is not a mediaplayer.
alias: surrounding check
description: ""
triggers:
- command:
- What is happening around the house
- " What's happening around the house"
- check surroundings
trigger: conversation
conditions: []
actions:
- data:
duration: 10
max_frames: 3
include_filename: true
target_width: 1280
max_tokens: 100
temperature: 0.2
generate_title: false
expose_images: false
provider: 01JJ2KWA02PY7PK4GSDFGHGFDXHED
remember: true
image_entity:
- camera.192_168_188_22
model: llava:7b
message: Describe what you see in one sentence.
response_variable: response
action: llmvision.stream_analyzer
- data:
message: "{{ response }}"
entity_id: tts.piper_2
action: tts.speak
- data:
level: info
message: "Response from stream analyzer: {{ response }}"
action: system_log.write
mode: single
