Using 2 x PCF8574 with esphome
I am try to set up esphome to use two pcf8574 devices. I have the model that can be connected one to eachother, If I load on esp32 a scan i2c code with arduino I can see both devices on addresses 0x20 and 0x24 (i changed address on the second one).
I2c bus is wired on 21/22 on esp32.
However I can t manage esphome to see and use both of them,
This is my code
captive_portal:
i2c:
   - id: bus_a
     sda: 21
     scl: 22
     scan: True
pcf8574:
  - id: 'pcf8574_hub_0'
    address: 0x20
    pcf8575: false
    i2c_id: bus_a
  - id: 'pcf8574_hub_1'
    address: 0x24
    pcf8575: false
    i2c_id: bus_a
switch:
  - platform: gpio
    pin:
      pcf8574: pcf8574_hub_0
      number: 0
      mode:
        output: true
    inverted: false
  - platform: gpio
    pin:
      number: 1
      mode:
        output: true
    inverted: false
and this is the log after load the code
INFO ESPHome 2023.10.6
INFO Reading configuration /config/esphome/tablou-ct.yaml...
INFO Starting log output from 192.168.10.42 using esphome API
INFO Successfully connected to 192.168.10.42
[16:39:13][I][app:102]: ESPHome version 2023.10.6 compiled on Nov 12 2023, 16:27:58
[16:39:13][C][wifi:546]: WiFi:
[16:39:13][C][wifi:382]:   Local MAC: A8:42:E3:49:3C:C4
[16:39:13][C][wifi:383]:   SSID: [redacted]
[16:39:13][C][wifi:384]:   IP Address: 192.168.10.42
[16:39:13][C][wifi:386]:   BSSID: [redacted]
[16:39:13][C][wifi:387]:   Hostname: 'tablou-ct'
[16:39:13][C][wifi:389]:   Signal strength: -69 dB ▂▄▆█
[16:39:13][C][wifi:393]:   Channel: 6
[16:39:13][C][wifi:394]:   Subnet: 255.255.255.0
[16:39:13][C][wifi:395]:   Gateway: 192.168.10.1
[16:39:13][C][wifi:396]:   DNS1: 0.0.0.0
[16:39:13][C][wifi:397]:   DNS2: 0.0.0.0
[16:39:13][C][logger:416]: Logger:
[16:39:13][C][logger:417]:   Level: DEBUG
[16:39:13][C][logger:418]:   Log Baud Rate: 115200
[16:39:13][C][logger:420]:   Hardware UART: UART0
[16:39:13][C][i2c.arduino:053]: I2C Bus:
[16:39:13][C][i2c.arduino:054]:   SDA Pin: GPIO21
[16:39:13][C][i2c.arduino:055]:   SCL Pin: GPIO22
[16:39:13][C][i2c.arduino:056]:   Frequency: 50000 Hz
[16:39:13][C][i2c.arduino:059]:   Recovery: bus successfully recovered
[16:39:13][I][i2c.arduino:069]: Results from i2c bus scan:
[16:39:13][I][i2c.arduino:075]: Found i2c device at address 0x20
[16:39:13][C][pcf8574:021]: PCF8574:
[16:39:13][C][pcf8574:022]:   Address: 0x20
[16:39:13][C][pcf8574:023]:   Is PCF8575: NO
[16:39:13][C][pcf8574:022]:   Address: 0x24
[16:39:13][E][pcf8574:025]: Communication with PCF8574 failed!
[16:39:13][C][switch.gpio:068]: GPIO Switch 'relay_01'
[16:39:13][C][switch.gpio:091]:   Restore Mode: always OFF
[16:39:13][C][switch.gpio:031]:   Pin: 0 via PCF8574
[16:39:13][C][switch.gpio:068]: GPIO Switch 'relay_02'
[16:39:13][C][switch.gpio:031]:   Pin: 1 via PCF8574
[16:39:13][C][switch.gpio:068]: GPIO Switch 'relay_03'
[16:39:13][C][switch.gpio:031]:   Pin: 2 via PCF8574
[16:39:13][C][switch.gpio:068]: GPIO Switch 'relay_04'
[16:39:13][C][switch.gpio:031]:   Pin: 3 via PCF8574
[16:39:13][C][switch.gpio:068]: GPIO Switch 'relay_05'
[16:39:13][C][switch.gpio:031]:   Pin: 4 via PCF8574
[16:39:14][C][switch.gpio:068]: GPIO Switch 'relay_06'
[16:39:14][C][switch.gpio:091]:   Restore Mode: always OFF
[16:39:14][C][switch.gpio:031]:   Pin: 5 via PCF8574
[16:39:14][C][switch.gpio:068]: GPIO Switch 'relay_07'
[16:39:14][C][switch.gpio:031]:   Pin: 6 via PCF8574
[16:39:14][C][switch.gpio:068]: GPIO Switch 'relay_08'
[16:39:14][C][switch.gpio:031]:   Pin: 7 via PCF8574
[16:39:14][C][switch.gpio:068]: GPIO Switch 'relay_09'
[16:39:14][C][switch.gpio:031]:   Pin: 0 via PCF8574
[16:39:14][C][captive_portal:088]: Captive Portal:
[16:39:14][C][mdns:115]: mDNS:
[16:39:14][C][mdns:116]:   Hostname: tablou-ct
[16:39:14][C][ota:097]: Over-The-Air Updates:
[16:39:14][C][ota:098]:   Address: 192.168.10.42:3232
[16:39:14][C][ota:101]:   Using Password.
[16:39:14][C][api:139]: API Server:
[16:39:14][C][api:140]:   Address: 192.168.10.42:6053
[16:39:14][C][api:144]:   Using noise encryption: NO
Seems it can t see both pcf and also get that error communicating with pcf…
Any idea what I am doing wrong ?
Thank you very much
