I have a Panasonic PT-VW340Z, which has PJLink and can be controlled from Home Assistant using a media card.
However it says it doesn’t have a unique ID, and doesn’t appear in Entities, so I can’t select it in Automations.
Is this a limitation of the PJLink configuration on the projector or within Home Assistant?
Hi, did you get this one sorted? I’m the same, pjlink works fine, I can create a dashboard button but cant set it to turn on in an automation.
Sadly I haven’t got any further with this; the projector has been packed away while we have work done.
The PJLink configuration doesn’t allow for a unique identification, which seems key, so that’s putting a block on my moving forward.
I’m not sure if you guys noticed, but this seems to work now. If you automate with “Call Service” and “Media Player: Turn On” it should show you your PJLink-enabled projector. Or, at least, it does for me.
Something to note: it looks like virtually no one uses the PJLink integration - two active installations?
The PJLink integration was introduced in Home Assistant 0.76, and it’s used by 2 active installations.
Now 3 PJLink use this via HomeAsistant
I have an VideoWall at work 3x3 Panasonic TH-49LFV8W screens which I’m trying to turn off/on via a schedule via HomeAsistant.
I can turn off/on via schedule via Panasonic software Multi Monitoring & Control Software via PJLink protocoal. Default password for panasonic PJLink is “@Panasonic”. Maybe I want to replace this with HomeAssistant, because seems this program needs to be running in foreground on a server.
With HomeAssistant add-on file editor I edited configuration.yaml
media_player:
- platform: pjlink
host: 10.30.79.201
port: 4352 # Default PJLink port
password: “@Panasonic”
name: LFV8-001 - platform: pjlink
host: 10.30.79.202
Suddenly appeared:
And I could turn it off once.
Now trying to add an automation.
Added now all screens. Hopefully all screens will appear instead of error:
This entity (‘media_player.lfv8_001’) does not have a unique ID, therefore its settings cannot be managed from the UI. See the documentation for more detail.
Turns out the “Suddenly appeared” part has been my failing all along . I’ve been trying to use the media_player attribute to configuration.yaml, and not seeing anything.
Restarted Home Assistant, there it is!
Thank you for verifying I was on the right track
