Using an AppDaemon app
I am trying to use this GitHub - xaf/qolsysgw: Qolsys IQ Panel 2+ gateway to an Home Assistant Alarm Control Panel
I am using the AppDaemon addon and it is running and shows the default HelloWorld.
For the Qolsys Gateway it says to add the apps.yaml to the /hass/config/appdaemon/ folder however it doesn’t show up in the AppDaemon web interface and the log says it only found 1 app.
The AppDaemon log also shows “Configuration read from: /config/appdaemon.yaml” but I can’t find this file and it halso has “Loading App Module: /config/apps/hello.py” and I also can not find either the apps folder or the hello.py.
I assume I am missing something simple however I am not sure what
I have the same problem, did you solve the problem?
ok, i just solved the problem. Hello.py is in add_configs. Use samba share, you just need to connect to \homeassistant.local\addon_configs
