I’m trying to set up a command_line
sensor for monitoring the hardrive temperature on the host of HASS.io .
I’m running Hass.Io on a Intel NUC running Debian.
- platform: command_line
command: "smartclt -A /dev/sdb | grep Temperature_Celcius | awk '{print $10}'"
unit_of_measurement: "°C"
But it’s not working at all.
How does command_line sensor and shell_command work when HassIO runs in this way?
I’m thinking that I maybe need to ssh from the hassio container to the host operating system and then run the command?
Any ideas?
I’m using shell scripts via cron to publish values to mqtt on local or remote hosts.
In HA i show the values with the MQTT Sensor
lolouk44
(lolouk44)
July 19, 2018, 12:29pm
3
What does your log say?
I’m not familiar with smartctl command. Any chance it requires su privileges?
Alternatively I’ve personally taken the same approach as @VDRainer
When I run the smartctl command from debian host I have to use sudo yes.
I could try to disable the sudo password and see if “sudo smartctl …” works.
Otherwise I think I will try @VDRainer and yours solution with cron and MQTT, sounds neat.
Not luck with using sudo
and disabling sudo password on the host.
I guess I have to go with cronjob+mqtt solution.
But I still would like to understand how to get command_line sensor to work on HassIO!
I managed to get it working at last!
Basicly I set up an ssh connection from the home assistant docker container to the host system. Followed this guide, https://megamorphf.github.io/homeassistant/hyperion/ssh/hassio/2018/01/22/controlling-anything-via-ssh.html , except for the first part as I’m running on a NUC through debian and already have access to the operating system.
This is final configuration:
name: HDD1 Temperatur
command: "ssh -i /config/ssh/id_rsa -o StrictHostKeyChecking=no [email protected] sudo smartctl -A /dev/sdb | grep Temperature_Celsius | awk '{print $10}'"
Works as a charm!
myca5a
(Myca5a)
May 27, 2020, 1:53pm
7
Trisk3lion:
smartctl
Can you help me ?
I will wish to obtain the temperature from another raspberry.
scan_interval: 300
command: ssh -i /config/.ssh/id_rsa -o StrictHostKeyChecking=no -q [email protected] sensors
unit_of_measurement: '°C'
Not working
However in the terminal on my HA :
works !
Best regards
Trisk3lion:
command_line
Does it help if you put the command in double quotes (“…”) or single (‘…’)?
scan_interval: 300
command: "ssh -i /config/.ssh/id_rsa -o StrictHostKeyChecking=no -q [email protected] sensors"
myca5a
(Myca5a)
May 27, 2020, 2:23pm
9
The same.
I don’t understand, but in the raspberry logs (/var/log/auth.log)
Failed password
In my HA logs : Command failed
