I have 2 battery operated wall switches from düwi lying around. They’re these type of devices:
I’m trying to get them working with Home assistant, but run into some trouble.
I can include them in home assistant, after which they sow up as “complete” in Z-Wave Manager.
The problem is that when I press any button on the switch, the led blinks red-green, acording to the manuel that means “Not programmed” (see manual here: https://doc.eedomus.com/files/Duewi_ZW_WS.pdf)
I have no idea what I should program about it, all I can do in the z-wave manager is set a “Node group association”, there are no other parameters there. Any idea where I should go from here?
This is what the device looks like in home assistant:
This are all entries I see for it in the OZW log:
2018-02-26 16:41:55.135 Detail, Node043, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2018-02-26 16:41:55.135 Detail, Node043, QueryStage_ProtocolInfo
2018-02-26 16:41:55.135 Detail, Node043, Queuing (Query) Get Node Protocol Info (Node=43): 0x01, 0x04, 0x00, 0x41, 0x2b, 0x91
2018-02-26 16:41:55.135 Detail, Node043, Queuing (Query) Query Stage Complete (ProtocolInfo)
2018-02-26 16:41:55.136 Info, Node043, Initializing Node. New Node: true (true)
2018-02-26 16:41:55.136 Detail, Node043, Notification: NodeAdded
2018-02-26 16:41:55.159 Info, Node043, Sending (Query) message (Callback ID=0x00, Expected Reply=0x41) - Get Node Protocol Info (Node=43): 0x01, 0x04, 0x00, 0x41, 0x2b, 0x91
2018-02-26 16:41:55.161 Detail, Node043, Received: 0x01, 0x09, 0x01, 0x41, 0x12, 0x96, 0x00, 0x01, 0x01, 0x01, 0x33
2018-02-26 16:41:55.162 Info, Node043, Received reply to FUNC_ID_ZW_GET_NODE_PROTOCOL_INFO
2018-02-26 16:41:55.162 Info, Node043, Protocol Info for Node 43:
2018-02-26 16:41:55.162 Info, Node043, Listening = false
2018-02-26 16:41:55.162 Info, Node043, Frequent = false
2018-02-26 16:41:55.162 Info, Node043, Beaming = true
2018-02-26 16:41:55.162 Info, Node043, Routing = false
2018-02-26 16:41:55.162 Info, Node043, Max Baud Rate = 40000
2018-02-26 16:41:55.162 Info, Node043, Version = 3
2018-02-26 16:41:55.162 Info, Node043, Security = false
2018-02-26 16:41:55.162 Info, Node043, Basic device class (0x01) - Controller
2018-02-26 16:41:55.162 Info, Node043, Generic device Class (0x01) - Remote Controller
2018-02-26 16:41:55.162 Info, Node043, Specific device class (0x01) - Portable Remote Controller
2018-02-26 16:41:55.162 Info, Node043, COMMAND_CLASS_BASIC is not mapped
2018-02-26 16:41:55.163 Info, Node043, Mandatory Command Classes for Node 43:
2018-02-26 16:41:55.163 Info, Node043, COMMAND_CLASS_WAKE_UP
2018-02-26 16:41:55.163 Info, Node043, Mandatory Command Classes controlled by Node 43:
2018-02-26 16:41:55.163 Info, Node043, COMMAND_CLASS_BASIC
2018-02-26 16:41:55.163 Detail, Node043, Removing current message
2018-02-26 16:41:55.163 Detail, Node043, Notification: NodeProtocolInfo
2018-02-26 16:41:55.166 Detail, Node043, Notification: ValueAdded
2018-02-26 16:41:55.171 Detail, Node043, Query Stage Complete (ProtocolInfo)
2018-02-26 16:41:55.171 Detail, Node043, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2018-02-26 16:41:55.171 Detail, Node043, QueryStage_Probe
2018-02-26 16:41:55.171 Info, Node043, NoOperation::Set - Routing=true
2018-02-26 16:41:55.171 Detail, Node043, Queuing (NoOp) NoOperation_Set (Node=43): 0x01, 0x09, 0x00, 0x13, 0x2b, 0x02, 0x00, 0x00, 0x25, 0x13, 0xfa
2018-02-26 16:41:55.171 Detail, Node043, Queuing (Query) Query Stage Complete (Probe)
2018-02-26 16:41:55.171 Info, Node043, Sending (NoOp) message (Callback ID=0x13, Expected Reply=0x13) - NoOperation_Set (Node=43): 0x01, 0x09, 0x00, 0x13, 0x2b, 0x02, 0x00, 0x00, 0x25, 0x13, 0xfa
2018-02-26 16:41:55.179 Detail, Node043, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-02-26 16:41:55.179 Detail, Node043, ZW_SEND_DATA delivered to Z-Wave stack
2018-02-26 16:41:55.195 Detail, Node043, Received: 0x01, 0x07, 0x00, 0x13, 0x13, 0x00, 0x00, 0x02, 0xfa
2018-02-26 16:41:55.196 Detail, Node043, ZW_SEND_DATA Request with callback ID 0x13 received (expected 0x13)
2018-02-26 16:41:55.196 Info, Node043, Request RTT 24 Average Request RTT 24
2018-02-26 16:41:55.196 Detail, Node043, Removing current message
2018-02-26 16:41:55.196 Detail, Node043, Notification: Notification - NoOperation
2018-02-26 16:41:55.199 Detail, Node043, Query Stage Complete (Probe)
2018-02-26 16:41:55.199 Detail, Node043, AdvanceQueries queryPending=0 queryRetries=0 queryStage=WakeUp live=1
2018-02-26 16:41:55.200 Detail, Node043, QueryStage_WakeUp
2018-02-26 16:41:55.200 Detail, Node043, QueryStage_ManufacturerSpecific1
2018-02-26 16:41:55.200 Detail, Node043, Checking for ManufacturerSpecific CC and Requesting values if present on this node
2018-02-26 16:41:55.200 Detail, Node043, QueryStage_NodeInfo
2018-02-26 16:41:55.200 Detail, Node043, Queuing (Query) Request Node Info (Node=43): 0x01, 0x04, 0x00, 0x60, 0x2b, 0xb0
2018-02-26 16:41:55.200 Detail, Node043, Queuing (Query) Query Stage Complete (NodeInfo)
2018-02-26 16:41:55.200 Info, Node043, Sending (Query) message (Callback ID=0x00, Expected Reply=0x49) - Request Node Info (Node=43): 0x01, 0x04, 0x00, 0x60, 0x2b, 0xb0
2018-02-26 16:41:55.207 Detail, Node043, Received: 0x01, 0x04, 0x01, 0x60, 0x01, 0x9b
2018-02-26 16:41:55.239 Detail, Node043, Received: 0x01, 0x12, 0x00, 0x49, 0x84, 0x2b, 0x0c, 0x01, 0x01, 0x01, 0x72, 0x80, 0x85, 0xef, 0x20, 0x26, 0x27, 0x85, 0x82, 0xb8
2018-02-26 16:41:55.239 Info, Node043, UPDATE_STATE_NODE_INFO_RECEIVED from node 43
2018-02-26 16:41:55.239 Info, Node043, Optional command classes for node 43:
2018-02-26 16:41:55.239 Info, Node043, COMMAND_CLASS_MANUFACTURER_SPECIFIC
2018-02-26 16:41:55.239 Info, Node043, COMMAND_CLASS_BATTERY
2018-02-26 16:41:55.239 Info, Node043, COMMAND_CLASS_ASSOCIATION
2018-02-26 16:41:55.239 Info, Node043, Optional command classes controlled by node 43:
2018-02-26 16:41:55.240 Info, Node043, COMMAND_CLASS_BASIC (Existing)
2018-02-26 16:41:55.240 Info, Node043, COMMAND_CLASS_SWITCH_MULTILEVEL
2018-02-26 16:41:55.240 Info, Node043, COMMAND_CLASS_SWITCH_ALL
2018-02-26 16:41:55.240 Info, Node043, COMMAND_CLASS_ASSOCIATION (Existing)
2018-02-26 16:41:55.240 Info, Node043, COMMAND_CLASS_HAIL
2018-02-26 16:41:55.240 Detail, Node043, Expected reply was received
2018-02-26 16:41:55.240 Detail, Node043, Message transaction complete
2018-02-26 16:41:55.240 Detail, Node043, Removing current message
2018-02-26 16:41:55.240 Detail, Node043, Notification: ValueAdded
2018-02-26 16:41:55.245 Detail, Node043, Notification: ValueAdded
2018-02-26 16:41:55.249 Detail, Node043, Notification: ValueAdded
2018-02-26 16:41:55.254 Detail, Node043, Notification: ValueAdded
2018-02-26 16:41:55.263 Detail, Node043, Notification: ValueAdded
2018-02-26 16:41:55.272 Detail, Node043, Notification: ValueAdded
2018-02-26 16:41:55.281 Detail, Node043, Notification: ValueAdded
2018-02-26 16:41:55.290 Detail, Node043, Query Stage Complete (NodeInfo)
2018-02-26 16:41:55.291 Detail, Node043, AdvanceQueries queryPending=0 queryRetries=0 queryStage=NodePlusInfo live=1
2018-02-26 16:41:55.291 Detail, Node043, QueryStage_NodePlusInfo
2018-02-26 16:41:55.291 Detail, Node043, QueryStage_SecurityReport
2018-02-26 16:41:55.291 Detail, Node043, QueryStage_ManufacturerSpecific2
2018-02-26 16:41:55.291 Detail, Node043, Queuing (Query) ManufacturerSpecificCmd_Get (Node=43): 0x01, 0x09, 0x00, 0x13, 0x2b, 0x02, 0x72, 0x04, 0x25, 0x14, 0x8b
2018-02-26 16:41:55.291 Detail, Node043, Queuing (Query) Query Stage Complete (ManufacturerSpecific2)
2018-02-26 16:41:55.291 Info, Node043, Sending (Query) message (Callback ID=0x14, Expected Reply=0x04) - ManufacturerSpecificCmd_Get (Node=43): 0x01, 0x09, 0x00, 0x13, 0x2b, 0x02, 0x72, 0x04, 0x25, 0x14, 0x8b
2018-02-26 16:41:55.299 Detail, Node043, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-02-26 16:41:55.299 Detail, Node043, ZW_SEND_DATA delivered to Z-Wave stack
2018-02-26 16:41:55.315 Detail, Node043, Received: 0x01, 0x07, 0x00, 0x13, 0x14, 0x00, 0x00, 0x02, 0xfd
2018-02-26 16:41:55.316 Detail, Node043, ZW_SEND_DATA Request with callback ID 0x14 received (expected 0x14)
2018-02-26 16:41:55.316 Info, Node043, Request RTT 24 Average Request RTT 24
2018-02-26 16:41:55.327 Detail, Node043, Received: 0x01, 0x0e, 0x00, 0x04, 0x00, 0x2b, 0x08, 0x72, 0x05, 0x00, 0x64, 0x50, 0x02, 0x00, 0x00, 0x97
2018-02-26 16:41:55.328 Info, Node043, Response RTT 36 Average Response RTT 36
2018-02-26 16:41:55.355 Info, Node043, Received manufacturer specific report from node 43: Manufacturer=Popp / Duwi, Product=Wireless Flush Mounted Switch
2018-02-26 16:41:55.355 Info, Node043, Node Identity Codes: 0064:5002:0000
2018-02-26 16:41:55.355 Detail, Node043, Expected reply and command class was received
2018-02-26 16:41:55.355 Detail, Node043, Message transaction complete
2018-02-26 16:41:55.356 Detail, Node043, Removing current message
2018-02-26 16:41:55.356 Detail, Node043, Notification: NodeNaming
2018-02-26 16:41:55.369 Detail, Node043, Query Stage Complete (ManufacturerSpecific2)
2018-02-26 16:41:55.369 Detail, Node043, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Versions live=1
2018-02-26 16:41:55.369 Detail, Node043, QueryStage_Versions
2018-02-26 16:41:55.369 Detail, Node043, QueryStage_Instances
2018-02-26 16:41:55.369 Info, Node043, Essential node queries are complete
2018-02-26 16:41:55.370 Detail, Node043, QueryStage_Static
2018-02-26 16:41:55.370 Detail, Node043, Queuing (Query) AssociationCmd_GroupingsGet (Node=43): 0x01, 0x09, 0x00, 0x13, 0x2b, 0x02, 0x85, 0x05, 0x25, 0x15, 0x7c
2018-02-26 16:41:55.370 Detail, Node043, Queuing (Query) Query Stage Complete (Static)
2018-02-26 16:41:55.370 Detail, Node043, Notification: EssentialNodeQueriesComplete
2018-02-26 16:41:55.378 Info, Node043, Sending (Query) message (Callback ID=0x15, Expected Reply=0x04) - AssociationCmd_GroupingsGet (Node=43): 0x01, 0x09, 0x00, 0x13, 0x2b, 0x02, 0x85, 0x05, 0x25, 0x15, 0x7c
2018-02-26 16:41:55.385 Detail, Node043, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-02-26 16:41:55.385 Detail, Node043, ZW_SEND_DATA delivered to Z-Wave stack
2018-02-26 16:41:55.403 Detail, Node043, Received: 0x01, 0x07, 0x00, 0x13, 0x15, 0x00, 0x00, 0x02, 0xfc
2018-02-26 16:41:55.403 Detail, Node043, ZW_SEND_DATA Request with callback ID 0x15 received (expected 0x15)
2018-02-26 16:41:55.403 Info, Node043, Request RTT 25 Average Request RTT 24
2018-02-26 16:41:55.413 Detail, Node043, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x2b, 0x03, 0x85, 0x06, 0x01, 0x58
2018-02-26 16:41:55.414 Info, Node043, Response RTT 35 Average Response RTT 35
2018-02-26 16:41:55.414 Info, Node043, Received Association Groupings report from node 43. Number of groups is 1
2018-02-26 16:41:55.414 Detail, Node043, Expected reply and command class was received
2018-02-26 16:41:55.414 Detail, Node043, Message transaction complete
2018-02-26 16:41:55.414 Detail, Node043, Removing current message
2018-02-26 16:41:55.414 Detail, Node043, Query Stage Complete (Static)
2018-02-26 16:41:55.414 Detail, Node043, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Associations live=1
2018-02-26 16:41:55.414 Detail, Node043, QueryStage_Associations
2018-02-26 16:41:55.414 Info, Node043, Number of association groups reported for node 43 is 1.
2018-02-26 16:41:55.414 Info, Node043, Get Associations for group 1 of node 43
2018-02-26 16:41:55.414 Detail, Node043, Queuing (Send) AssociationCmd_Get (Node=43): 0x01, 0x0a, 0x00, 0x13, 0x2b, 0x03, 0x85, 0x02, 0x01, 0x25, 0x16, 0x7b
2018-02-26 16:41:55.414 Detail, Node043, Queuing (Query) Query Stage Complete (Associations)
2018-02-26 16:41:55.415 Info, Node043, Sending (Send) message (Callback ID=0x16, Expected Reply=0x04) - AssociationCmd_Get (Node=43): 0x01, 0x0a, 0x00, 0x13, 0x2b, 0x03, 0x85, 0x02, 0x01, 0x25, 0x16, 0x7b
2018-02-26 16:41:55.423 Detail, Node043, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-02-26 16:41:55.424 Detail, Node043, ZW_SEND_DATA delivered to Z-Wave stack
2018-02-26 16:41:55.441 Detail, Node043, Received: 0x01, 0x07, 0x00, 0x13, 0x16, 0x00, 0x00, 0x02, 0xff
2018-02-26 16:41:55.441 Detail, Node043, ZW_SEND_DATA Request with callback ID 0x16 received (expected 0x16)
2018-02-26 16:41:55.441 Info, Node043, Request RTT 26 Average Request RTT 25
2018-02-26 16:41:55.451 Detail, Node043, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x2b, 0x05, 0x85, 0x03, 0x01, 0x20, 0x00, 0x79
2018-02-26 16:41:55.451 Info, Node043, Response RTT 36 Average Response RTT 35
2018-02-26 16:41:55.451 Info, Node043, Received Association report from node 43, group 1, containing 0 associations
2018-02-26 16:41:55.452 Info, Node043, Querying associations for node 43 is complete.
2018-02-26 16:41:55.452 Info, Node043, Adding the controller to group 1 (Group 1) of node 43
2018-02-26 16:41:55.452 Info, Node043, Association::Set - Adding node 1 to group 1 of node 43
2018-02-26 16:41:55.452 Detail, Node043, Queuing (Send) AssociationCmd_Set (Node=43): 0x01, 0x0b, 0x00, 0x13, 0x2b, 0x04, 0x85, 0x01, 0x01, 0x01, 0x25, 0x17, 0x7e
2018-02-26 16:41:55.452 Info, Node043, Get Associations for group 1 of node 43
2018-02-26 16:41:55.452 Detail, Node043, Queuing (Send) AssociationCmd_Get (Node=43): 0x01, 0x0a, 0x00, 0x13, 0x2b, 0x03, 0x85, 0x02, 0x01, 0x25, 0x18, 0x75
2018-02-26 16:41:55.452 Detail, Node043, Expected reply and command class was received
2018-02-26 16:41:55.452 Detail, Node043, Message transaction complete
2018-02-26 16:41:55.452 Detail, Node043, Removing current message
2018-02-26 16:41:55.452 Detail, Node043, Notification: Group
2018-02-26 16:41:55.458 Info, Node043, Sending (Send) message (Callback ID=0x17, Expected Reply=0x13) - AssociationCmd_Set (Node=43): 0x01, 0x0b, 0x00, 0x13, 0x2b, 0x04, 0x85, 0x01, 0x01, 0x01, 0x25, 0x17, 0x7e
2018-02-26 16:41:55.467 Detail, Node043, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-02-26 16:41:55.467 Detail, Node043, ZW_SEND_DATA delivered to Z-Wave stack
2018-02-26 16:41:55.483 Detail, Node043, Received: 0x01, 0x07, 0x00, 0x13, 0x17, 0x00, 0x00, 0x02, 0xfe
2018-02-26 16:41:55.483 Detail, Node043, ZW_SEND_DATA Request with callback ID 0x17 received (expected 0x17)
2018-02-26 16:41:55.483 Info, Node043, Request RTT 25 Average Request RTT 25
2018-02-26 16:41:55.484 Detail, Node043, Removing current message
2018-02-26 16:41:55.484 Info, Node043, Sending (Send) message (Callback ID=0x18, Expected Reply=0x04) - AssociationCmd_Get (Node=43): 0x01, 0x0a, 0x00, 0x13, 0x2b, 0x03, 0x85, 0x02, 0x01, 0x25, 0x18, 0x75
2018-02-26 16:41:55.492 Detail, Node043, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-02-26 16:41:55.492 Detail, Node043, ZW_SEND_DATA delivered to Z-Wave stack
2018-02-26 16:41:55.508 Detail, Node043, Received: 0x01, 0x07, 0x00, 0x13, 0x18, 0x00, 0x00, 0x02, 0xf1
2018-02-26 16:41:55.509 Detail, Node043, ZW_SEND_DATA Request with callback ID 0x18 received (expected 0x18)
2018-02-26 16:41:55.509 Info, Node043, Request RTT 24 Average Request RTT 24
2018-02-26 16:41:55.555 Detail, Node043, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x2b, 0x05, 0x85, 0x03, 0x01, 0x20, 0x00, 0x79
2018-02-26 16:41:55.555 Info, Node043, Response RTT 71 Average Response RTT 53
2018-02-26 16:41:55.555 Info, Node043, Received Association report from node 43, group 1, containing 0 associations
2018-02-26 16:41:55.555 Detail, Node043, Expected reply and command class was received
2018-02-26 16:41:55.556 Detail, Node043, Message transaction complete
2018-02-26 16:41:55.556 Detail, Node043, Removing current message
2018-02-26 16:41:55.556 Detail, Node043, Notification: Group
2018-02-26 16:41:55.556 Detail, Node043, Query Stage Complete (Associations)
2018-02-26 16:41:55.557 Detail, Node043, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Neighbors live=1
2018-02-26 16:41:55.557 Detail, Node043, QueryStage_Neighbors
2018-02-26 16:41:55.557 Detail, Node043, Queuing (Command) Get Routing Info (Node=43): 0x01, 0x07, 0x00, 0x80, 0x2b, 0x00, 0x00, 0x03, 0x50
2018-02-26 16:41:55.557 Detail, Node043, Queuing (Query) Query Stage Complete (Neighbors)
2018-02-26 16:41:55.557 Info, Node043, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=43): 0x01, 0x07, 0x00, 0x80, 0x2b, 0x00, 0x00, 0x03, 0x50
2018-02-26 16:41:55.562 Detail, Node043, Received: 0x01, 0x20, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5e
2018-02-26 16:41:55.562 Info, Node043, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2018-02-26 16:41:55.562 Info, Node043, Neighbors of this node are:
2018-02-26 16:41:55.562 Info, Node043, (none reported)
2018-02-26 16:41:55.562 Detail, Node043, Removing current message
2018-02-26 16:41:55.562 Detail, Node043, Query Stage Complete (Neighbors)
2018-02-26 16:41:55.562 Detail, Node043, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2018-02-26 16:41:55.563 Detail, Node043, QueryStage_Session
2018-02-26 16:41:55.563 Detail, Node043, QueryStage_Dynamic
2018-02-26 16:41:55.563 Detail, Node043, Queuing (Send) BatteryCmd_Get (Node=43): 0x01, 0x09, 0x00, 0x13, 0x2b, 0x02, 0x80, 0x02, 0x25, 0x19, 0x72
2018-02-26 16:41:55.563 Detail, Node043, Queuing (Query) Query Stage Complete (Dynamic)
2018-02-26 16:41:55.563 Info, Node043, Sending (Send) message (Callback ID=0x19, Expected Reply=0x04) - BatteryCmd_Get (Node=43): 0x01, 0x09, 0x00, 0x13, 0x2b, 0x02, 0x80, 0x02, 0x25, 0x19, 0x72
2018-02-26 16:41:55.572 Detail, Node043, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-02-26 16:41:55.572 Detail, Node043, ZW_SEND_DATA delivered to Z-Wave stack
2018-02-26 16:41:55.711 Detail, Node043, Received: 0x01, 0x07, 0x00, 0x13, 0x19, 0x00, 0x00, 0x0d, 0xff
2018-02-26 16:41:55.712 Detail, Node043, ZW_SEND_DATA Request with callback ID 0x19 received (expected 0x19)
2018-02-26 16:41:55.712 Info, Node043, Request RTT 148 Average Request RTT 86
2018-02-26 16:41:55.713 Detail, Node043, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x2b, 0x03, 0x80, 0x03, 0x40, 0x19
2018-02-26 16:41:55.713 Info, Node043, Response RTT 150 Average Response RTT 101
2018-02-26 16:41:55.714 Info, Node043, Received Battery report from node 43: level=64
2018-02-26 16:41:55.714 Detail, Node043, Initial read of value
2018-02-26 16:41:55.714 Detail, Node043, Expected reply and command class was received
2018-02-26 16:41:55.714 Detail, Node043, Message transaction complete
2018-02-26 16:41:55.714 Detail, Node043, Removing current message
2018-02-26 16:41:55.714 Detail, Node043, Notification: ValueChanged
2018-02-26 16:41:55.752 Detail, Node043, Query Stage Complete (Dynamic)
2018-02-26 16:41:55.752 Detail, Node043, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2018-02-26 16:41:55.752 Detail, Node043, QueryStage_Configuration
2018-02-26 16:41:55.752 Detail, Node043, QueryStage_Complete
2018-02-26 16:41:55.753 Detail, Node043, Queuing (WakeUp) WakeUpCmd_NoMoreInformation (Node=43): 0x01, 0x09, 0x00, 0x13, 0x2b, 0x02, 0x84, 0x08, 0x25, 0x1a, 0x7f
2018-02-26 16:41:55.753 Detail, Node043, Notification: NodeQueriesComplete
2018-02-26 16:41:55.756 Info, Node043, Sending (WakeUp) message (Callback ID=0x1a, Expected Reply=0x13) - WakeUpCmd_NoMoreInformation (Node=43): 0x01, 0x09, 0x00, 0x13, 0x2b, 0x02, 0x84, 0x08, 0x25, 0x1a, 0x7f
2018-02-26 16:41:55.765 Detail, Node043, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-02-26 16:41:55.765 Detail, Node043, ZW_SEND_DATA delivered to Z-Wave stack
2018-02-26 16:41:55.781 Detail, Node043, Received: 0x01, 0x07, 0x00, 0x13, 0x1a, 0x00, 0x00, 0x02, 0xf3
2018-02-26 16:41:55.781 Detail, Node043, ZW_SEND_DATA Request with callback ID 0x1a received (expected 0x1a)
2018-02-26 16:41:55.781 Info, Node043, Request RTT 24 Average Request RTT 55
2018-02-26 16:41:55.781 Info, Node043, Node 43 has been marked as asleep
2018-02-26 16:41:55.781 Detail, Node043, Removing current message
2018-02-26 16:41:55.782 Detail, Node043, Notification: Notification - Node Asleep
