satish-rpr
(Satish Rajanna)
January 4, 2026, 12:15pm
1
I am trying to work with Waveshare ESP32C6 1.83 device.
I am not able to get the display initialized correctly with the following esphome configuration:
display:
- platform: st7789v
model: custom
cs_pin: 5
dc_pin: 3
reset_pin: 4
setup_priority: -100 # Initialize first
width: 240
height: 284
offset_width: 0
offset_height: 0
I tried using esp idf framework along with above display configuration and could not get it to work
esp32:
board: "esp32-c6-devkitc-1"
variant: "ESP32C6"
flash_size: 16MB
framework:
type: esp-idf
How can I use esp idf framewaork and not worry about configuring display and touchscreen of the device ?
Your help is appreciated.
Thanking you
Satish Rajanna
Karosm
(Karosm)
January 4, 2026, 12:54pm
2
I’m not sure how to read your question… Just remove the display component from your code.
satish-rpr
(Satish Rajanna)
January 4, 2026, 1:28pm
3
@Karosm , thank you for your response. I am using lvgl to display widget on the screen. Lvgl would need display option and also touchscreen.
Probably my yaml configuration will explain better
My yaml configuration is as below:
Code for Waveshare ESP32C6 1.83 inch LCD Touch
Karosm
(Karosm)
January 4, 2026, 1:31pm
4
But you specifically asked not to configure display and touch…
satish-rpr
(Satish Rajanna)
January 4, 2026, 1:34pm
5
sorry for the confusion. I want to use edp idf framework and not have to configure the display and touch in yaml. The yaml configuration does not work as expected. But I need the display and touchscreen configuration from esp idf and not yaml.
satish-rpr
(Satish Rajanna)
January 4, 2026, 4:58pm
6
You still need to provide the display and touchscreen configurations in yaml. I was mistaken. Sorry for the confusion.
