Using external sensor as temperature sensor for Meross thermostat
Not sure if this is where I should post this, but I’ve searched around and haven’t found what I’m looking for or if it is even possible. I have a Meross MTS300 thermostat and several D1 minis with DHT22s attached for temperature and humidity readings throughout the house. I would like to use the temperature reading in the main living area from my d1 mini to act as the temperature sensor for my meross thermostat, but I haven’t had any luck. I’ve attempted to setup a generic thermostat, but the only switches I am able to use are the “fan hold” and “child lock”. I’ve also tried the “Better Thermostat” from HACS and all that did was turn off my thermostat completely. I have it functioning as before, but there’s sometimes a 4°F difference between the main living area and the hall where the thermostat is located. Any suggestions would be greatly appreciated!
