Running Frenck’s AppDaemon 4 add-on. Log is just showing the following continuously:
2020-04-13 16:05:20.445287 INFO HASS: Connected to Home Assistant 0.108.3
2020-04-13 16:05:20.493590 INFO HASS: Evaluating startup conditions
2020-04-13 16:05:20.560049 WARNING HASS: Error getting Home Assistant state for None
2020-04-13 16:05:20.560515 WARNING HASS: Code: 500, error: 500: Internal Server Error
2020-04-13 16:05:20.560835 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
2020-04-13 16:05:25.570885 INFO HASS: Connected to Home Assistant 0.108.3
2020-04-13 16:05:25.609048 INFO HASS: Evaluating startup conditions
2020-04-13 16:05:25.687633 WARNING HASS: Error getting Home Assistant state for None
2020-04-13 16:05:25.688277 WARNING HASS: Code: 500, error: 500: Internal Server Error
2020-04-13 16:05:25.688699 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
2020-04-13 16:05:30.698979 INFO HASS: Connected to Home Assistant 0.108.3
2020-04-13 16:05:30.741023 INFO HASS: Evaluating startup conditions
2020-04-13 16:05:30.806406 WARNING HASS: Error getting Home Assistant state for None
2020-04-13 16:05:30.807285 WARNING HASS: Code: 500, error: 500: Internal Server Error
2020-04-13 16:05:30.808084 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
2020-04-13 16:05:35.816596 INFO HASS: Connected to Home Assistant 0.108.3
2020-04-13 16:05:35.855111 INFO HASS: Evaluating startup conditions
2020-04-13 16:05:35.920971 WARNING HASS: Error getting Home Assistant state for None
2020-04-13 16:05:35.921618 WARNING HASS: Code: 500, error: 500: Internal Server Error
2020-04-13 16:05:35.922094 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
Here’s my appdaemon.yaml:
secrets: /config/secrets.yaml
logs:
main_log:
filename: /config/appdaemon/Logs/appdaemon.log
log_generations: 10
log_size: 999999
access_log:
filename: /config/appdaemon/Logs/appdaemonaccess.log
error_log:
filename: /config/appdaemon/Logs/appdaemonerr.log
appdaemon:
latitude: xx.676526
longitude: -xx.951106
elevation: xx
time_zone: America/New_York
plugins:
HASS:
type: hass
http:
url: http://127.0.0.1:5050
admin:
title: AppDaemon
stats_update: realtime
api:
hadashboard:
Help! - Thanks!!!
