Home assistance with frigate as an addon no longer supports Google Coral TPU due to the Python version above 3.9. Does anybody have a solution to it.
Hardware details:-
Rasspberry pi 5 8GB Ram
Google Coral TPU USB
O.S- Home Assistance version 14.2
Not sure what you mean by that. The addon uses its own python version.
Do you have a reference to that issue?
Ok so I am providing you with my details can you give me the solution to my problem.
lsusb
Bus 003 Device 001: ID 1d6b:0002 Linux 6.6.62-haos-raspi xhci-hcd xHCI Host Controller
Bus 002 Device 002: ID 1a6e:089a
Bus 001 Device 001: ID 1d6b:0002 Linux 6.6.62-haos-raspi xhci-hcd xHCI Host Controller
Bus 004 Device 001: ID 1d6b:0003 Linux 6.6.62-haos-raspi xhci-hcd xHCI Host Controller
Bus 002 Device 001: ID 1d6b:0003 Linux 6.6.62-haos-raspi xhci-hcd xHCI Host Controller
Frigate logs when I am starting the app
F driver/usb/usb_driver.cc:1148] HandleQueuedBulkIn transfer in failed. Not found: USB transfer error 5 [LibUsbDataInCallback]
2025-02-11 06:36:23.552803927 Fatal Python error: Aborted
Attempting to load TPU as usb
2025-02-11 07:01:28.091252110 [2025-02-11 12:31:28] frigate.detectors.plugins.edgetpu_tfl ERROR : No EdgeTPU was detected. If you do not have a Coral device yet, you must configure CPU detectors.
Hardware:-
rasspiberry pi 5 8GB .
I have same hardware and OS. I am not seeing any errors. Coral TPU is recognised and working
OS details you are currently using.
frigate.yaml file details
detectors:
coral:
type: edgetpu
device: usb
mqtt:
host: xxx.xxx.xxx.xxx
port: 1883
topic_prefix: frigate
client_id: frigate
user:xxxxxx
password: xxxxxxxxxx
stats_interval: 60
cameras:
#simple camera example
Camera_166:
ffmpeg:
inputs:
- path: rtsp://xxxxxxxxxxxxxxxxxxxxxxxxxx
roles:
- detect
- record
detect:
width: 352
height: 288
fps: 5
record:
enabled: true
retain:
days: 7
mode: motion
alerts:
retain:
days: 14
detections:
retain:
days: 14
ffmpeg:
hwaccel_args: preset-rpi-64-h264
objects:
track:
- person
- dog
- cat
filters:
person:
# Optional: minimum widthheight of the bounding box for the detected object (default: 0)
min_area: 0
# Optional: maximum widthheight of the bounding box for the detected object (default: 24000000)
max_area: 100000
# Optional: minimum score for the object to initiate tracking (default: shown below)
min_score: 0.5
# Optional: minimum decimal percentage for tracked object’s computed score to be considered a true positive (default: shown below)
threshold: 0.7
version: 0.15-1
However, I must mention that when I use CPU detectors it’s working.
detectors:
coral:
type: edgetpu
device: usb
Not clear to me what your problem is exactly, but I would make backup copy of your yaml configuration and then start with bare bones configuration. Rebuild as there has been quite a few changes and I am on Frigate 0.15.0 (Full Access) Beta
I had the same issue =>
2025-02-17 10:13:38.456967387 Fatal Python error: Aborted
[2025-02-17 11:13:39] frigate.watchdog INFO : Detection appears to have stopped. Exiting Frigate…
This happened 4 times today (I get a notification when Frigate isn’t running). I could however start the service with no problems every time.
I just updated from 14.1 to 15.0.0. No issues so far
Extra info: I’m using a Intel Nuc with Google Edge Tpu and Truenas Server for recordings
