I’ve been using Home Assistant through Docker on my Asustor AS4004T (ADM 4.3.3.RC92). I’m now trying to add a Home Assistant Connect ZBT-1 to my setup, but I’m struggling to get the Home Assistant container to detect the device.
I’ve looked through what I can find on the web around similar problems, but having seen anything that matches my problem, or resolves it.
I think that the device is recognised, but that the Asustor may be missing the drivers to use it, if someone could confirm this that would be great (especially if you can point me to which drivers I could use to help make this work!)
My HA docker-compose file:
services:
homeassistant:
# customizable name
container_name: home-assistant
# must be image for your platform
image: ghcr.io/home-assistant/home-assistant:stable
volumes:
- /volume1/Docker/HomeAssistant/config:/config
- /etc/localtime:/etc/localtime:ro
- /run/dbus:/run/dbus:ro
# privileged: true
# devices:
# - /dev/usbdev3.8:/dev/ttyUSB0
restart: always
network_mode: host
I’ve tried both mapping the /dev/usbdev device manually to Docker, and also starting in privileged mode, but neither seems to change anything.
When I run lsusb, I can see the device:
/volume1/Docker/HomeAssistant $ lsusb
Bus 003 Device 002: ID 0bda:5411 Realtek Semiconductor Corp.:unknown device 5411
Bus 004 Device 002: ID 0bda:0411 Realtek Semiconductor Corp.:unknown device 0411
Bus 003 Device 013: ID 10c4:ea60 Silicon Labs:CP210x UART Bridge
However, in dmesg, the logs from immediately affter plugging in the ZBT-1 look like something goes wrong, and that’s why Home Assistant can’t see it:
/volume1/Docker/HomeAssistant $ dmesg
[271122.301308] xhci-hcd f2510000.usb3: Wait for xhci command complete left 1250 ms
[271122.393075] usb 3-1.2: new full-speed USB device number 14 using xhci-hcd
[271122.502525] usb 3-1.2: New USB device found, idVendor=10c4, idProduct=ea60
[271122.509526] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[271122.516984] usb 3-1.2: Product: Home Assistant Connect ZBT-1
[271122.522762] usb 3-1.2: Manufacturer: Nabu Casa
[271122.527329] usb 3-1.2: SerialNumber: e20d4c5fcb39ef1196e85ef454516304
[271122.547805] usbip-host 3-1.2:1.0: 3-1.2 is not in match_busid table... skip!
Thanks in advance for any help you can provide!
