This is a structure I’ve arrived at that makes large YAML configurations much easier to maintain. I’m putting it out there because I’d like the pattern to be discussed and, if people find it useful, perhaps adopted more widely.
As a Home Assistant configuration grows, simply splitting files by domain eventually stops being enough.
You can have:
automations/
scripts/
input_booleans/
sensors/
but then everything belonging to different systems gets mixed together. A Roborock automation sits next to an alarm automation, which sits next to a lighting automation.
Home Assistant packages provide a way to group related configuration, but the common examples I found tend to use packages as individual YAML files containing several domain keys.
I wanted something slightly different.
I wanted a package to represent a project, while still keeping the configuration inside that project organized by Home Assistant domain.
The result is a kind of nested include structure:
configuration.yaml
homeassistant:
packages: !include _packages/packages.yaml
roborock: !include roborock/roborock.yaml
_packages/roborock/roborock.yaml
input_boolean: !include_dir_merge_named input_booleans
input_select: !include_dir_merge_named input_selects
script: !include_dir_merge_named scripts
automation: !include_dir_merge_list automations
_packages/roborock/input_booleans/*.yaml
_packages/roborock/input_selects/*.yaml
_packages/roborock/scripts/*.yaml
_packages/roborock/automations/*.yaml
The important part is that every level has its own job.
packages.yaml knows about projects.
roborock.yaml knows which Home Assistant domains the Roborock project uses.
The individual files contain the actual configuration.
The package is a project container
My packages.yaml contains references to projects rather than configuration itself:
The project then defines its own domains:
This gives me:
_packages/
└── roborock/
├── roborock.yaml
├── automations/
├── input_booleans/
├── input_selects/
└── scripts/
So instead of having one huge roborock.yaml, the project itself has the same domain-based organization that I would normally use globally.
The individual files don’t contain package keys
This is an important part of the design.
For example:
# _packages/roborock/input_booleans/auto_clean.yaml
auto_clean:
There is no:
input_boolean:
in this file.
That key is supplied by the parent include:
Likewise, a script can simply be:
clean_kitchen:
sequence:
because the project file already establishes the script: context.
For understanding the structure, I think of each include as textual substitution. The include itself disappears and the resulting content takes its place, while the YAML context around it remains.
The final configuration is therefore conceptually no different from having written everything out manually.
Every include has its own relative path
Another important detail is that include paths are relative to the file containing the include.
So this:
# _packages/roborock/roborock.yaml
refers to:
It does not refer to some global scripts/ directory.
This is what makes the nested structure possible.
Each level effectively establishes a new reference point:
configuration.yaml
_shared still exists
I don’t use packages for everything.
My general configuration still lives in _shared:
_shared/
├── automations/
├── binary_sensors/
├── command_line/
├── input_booleans/
├── input_numbers/
├── input_selects/
├── scripts/
├── sensors/
For example, my main configuration can contain:
automation: !include_dir_merge_list _shared/automations/
input_boolean: !include_dir_merge_named _shared/input_booleans/
script: !include_dir_merge_named _shared/scripts/
sensor: !include_dir_merge_list _shared/sensors/
So I have two different levels of organization:
_shared/
general and small things
_packages/
self-contained projects
A tiny automation doesn’t need a project directory.
If something grows into a coherent system, it can become a project.
Moving things between the two is easy
Because the individual files don’t contain package keys, moving configuration between _packages and _shared doesn’t require rewriting the file.
For example:
can later become:
_shared/input_booleans/auto_clean.yaml
without changing the contents.
The context changes because the file is included somewhere else, but the configuration itself doesn’t need to change.
This also means that using packages doesn’t lock configuration into packages.
I use a project template
To make creating new projects consistent, I keep a template project directory.
It contains a template YAML file with all the domain include options commented out:
# --- Entity-ID-keyed domains ---
# group: !include_dir_merge_named groups
# input_boolean: !include_dir_merge_named input_booleans
# input_select: !include_dir_merge_named input_selects
# input_number: !include_dir_merge_named input_numbers
# input_text: !include_dir_merge_named input_text
# input_datetime: !include_dir_merge_named input_datetime
# script: !include_dir_merge_named scripts
# rest_command: !include_dir_merge_named rest_commands
# utility_meter: !include_dir_merge_named utility_meters
# counter: !include_dir_merge_named counters
# shell_command: !include_dir_merge_named shell_commands
# --- List-based / platform domains ---
# automation: !include_dir_merge_list automations
# scene: !include_dir_merge_list scenes
# template: !include_dir_merge_list templates
# rest: !include_dir_merge_list rest_sensors
# switch: !include_dir_merge_list switches
# sensor: !include_dir_merge_list sensors
# binary_sensor: !include_dir_merge_list binary_sensors
# light: !include_dir_merge_list lights
# notify: !include_dir_merge_list notify
# command_line: !include_dir_merge_list command_line
But the template isn’t just the YAML file.
The domain directories are already there too.
So when I create a new project, I can simply copy the entire template directory:
_template/
├── _template.yaml
├── automations/
├── binary_sensors/
├── command_line/
├── counters/
├── groups/
├── input_booleans/
├── input_datetime/
├── input_numbers/
├── input_selects/
├── input_text/
├── lights/
├── notify/
├── rest_commands/
├── rest_sensors/
├── scenes/
├── scripts/
├── sensors/
├── shell_commands/
├── switches/
├── templates/
└── utility_meters/
Then I rename the YAML file to the project name and remove the # from the domains I actually need.
For example, if a project needs only automations, scripts and input booleans:
The corresponding directories already exist because they came from the template.
Unused directories can simply remain empty.
The template also prevents dangling includes
I use a simple rule:
A domain include and its directory are always enabled together.
So if this is commented:
the sensors directory doesn’t need to exist.
If I uncomment it, the sensors directory is created or copied from the template.
This avoids having project files containing include statements pointing at directories that don’t exist.
The template therefore acts as a small scaffold for new projects rather than merely being a list of examples.
Adding a new project
Once the initial structure exists, adding a project is very simple.
I copy the template:
_template/
to:
roborock/
Then I configure the domains I actually use and add one line to packages.yaml:
That’s it.
The main configuration file doesn’t need to change.
Adding another project follows exactly the same pattern:
_packages/
├── packages.yaml
├── roborock/
├── alarm/
├── lighting/
└── something_else/
Each project is internally self-contained.
It is also non-destructive
One reason I like this approach is that it doesn’t require replacing my existing configuration.
The old _shared domain includes remain exactly where they were.
If I ever decide that I don’t want to use packages anymore, I can remove:
homeassistant:
from the main configuration.
The _shared configuration continues to work because it was never dependent on the package structure.
This makes experimenting with the organization relatively low-risk.
The resulting mental model
The structure ends up being:
project
individual configuration
rather than putting everything into global domain directories:
configuration from many unrelated projects
For me, that makes a large configuration much easier to navigate.
When I want to work on the Roborock system, I open roborock/.
When I want to work on a general automation, I look in _shared/automations/.
I don’t have to search through one enormous collection of unrelated automations, scripts and helpers.
The nice thing is that none of this requires a special mechanism beyond Home Assistant’s existing !include and !include_dir_merge_* functionality.
The useful part is the combination:
packages provide the project boundary, nested includes provide the domain boundary, and the individual YAML files contain only the actual configuration.
That particular combination is what I was looking for, and I couldn’t find much documentation describing it this way.
Once the structure is built, however, adding and maintaining projects becomes remarkably simple.
