Hi there!
I’m trying to set up the following automation, but I can’t wrap my head around how to go about it:
- Around the clock, at 6, 12, 18 & 1, switch [a pre-defined zone] to a ‘default’ scene.
- If light(s) is changed manually, override the above, for those light(s).
- If light(s) is turned off (dumb switch/unreachable), return to default scene.
Step 1 is simple enough, but to accomplish want - I feel like I need a input_boolean to keep track of whether a scene is default or not. Below is what I got so far, but I’m lost as to how to do the rest or maybe there’s an entirely different method of doing what I want?
- id: ''
alias: Default scene handler
description: Changes the scene depending on the time of day and checks for the default scene
- platform: time
at: '18:00:00'
#Below should be the input_boolean?
# And some condition to check Whether isDefault is true or not?
condition: []
#ie similar to...?
#- condition: state
#entity_id: input_boolean.isDefault
#state: "always(?)"
# [don't turn lights on if off]
#if True, change the scene? (For now I'm just toggling the light for easier testing)
- type: toggle
device_id:
entity_id: light.office_4
domain: light
mode: single
#Nice to have: 2 second fade on from off state, 5 seecond fade when changing (default) scenes
Thank you for your time to time and help if you can <3
