Using Klikaanklikuit as a bridge with HomeAssistant
Hi all,
I have a ICS-1000.
I want to use the ICS-1000 as a bridge and use Home Assistant to create automation’s (scenes) because COCO (KlikAanKlikUit) does not deliver an up-to-date-app and Home Assistant delivers more integrations. What I don’t prefer is a DIY solution, like dongles to create a separate bridge.
I can’t find any integration to connect the ICS-1000 although there is one for Homeridge there is none for Home Assistant.
Are you aware of any integration?
I’ve read all comments, but did not find an answer yet… So I started a new topic…
