I’m very new to ESPHome and YAML. I have a switch that I want to use to controll my light. I already created the basic configuration and it works.
Now I would like to add the ability to change brightness with doube click. It should work like this: If the light has more then 50% brightness, then dimm it to 10%, if it has less then 50%, set full brightness. So basically the doubleclick should toggle between 100% and 10%.
To do this, I need to create a condition based on the current brightness of the light. I need to get this value form HA end use it in ESPHome. I know hot to set the brigtness, but I can not figure out, how to get it and use it in a condition.
This would be an automation of course, and instead of doing it in a condition to check for the value as it is a little clunky for your use case - have as the trigger a double-click, no condition, and then for the action use if-then-else (which can also be nested) and you can have all of the logic there.
substitutions:
# Default name
# Default friendly name
friendly_name: "Athom Relay Switch"
# Allows ESP device to be automatically linked to an 'Area' in Home Assistant. Typically used for areas such as 'Lounge Room', 'Kitchen' etc
room: ""
# Description as appears in ESPHome & top of webserver page
device_description: "athom mini relay switch module"
# Project Name
project_name: "Athom Technology.Mini Relay Switch"
# Projection version denotes the release version of the yaml file, allowing checking of deployed vs latest version
project_version: "v1.1.3"
# Restore the relay (GPO switch) upon reboot to state:
light_restore_mode: RESTORE_DEFAULT_ON
# Define a domain for this device to use. i.e. iot.home.lan (so device will appear as athom-smart-plug-v2.iot.home.lan in DNS/DHCP logs)
dns_domain: ".local"
# Set timezone of the smart plug. Useful if the plug is in a location different to the HA server. Can be entered in unix Country/Area format (i.e. "Australia/Sydney")
timezone: ""
# Set the duration between the sntp service polling ntp.org servers for an update
sntp_update_interval: 6h
# Network time servers for your region, enter from lowest to highest priority. To use local servers update as per zones or countries at: https://www.ntppool.org/zone/@
sntp_server_1: "0.pool.ntp.org"
sntp_server_2: "1.pool.ntp.org"
sntp_server_3: "2.pool.ntp.org"
# Enables faster network connections, with last connected SSID being connected to and no full scan for SSID being undertaken
wifi_fast_connect: "true"
# Define logging level: NONE, ERROR, WARN, INFO, DEBUG (Default), VERBOSE, VERY_VERBOSE
log_level: "DEBUG"
# Enable or disable the use of IPv6 networking on the device
ipv6_enable: "false"
hass_light: light.svetlo_jidelni_stul
esphome:
friendly_name: "${friendly_name}"
comment: "${device_description}"
area: "${room}"
name_add_mac_suffix: true
min_version: 2024.6.0
project:
version: "${project_version}"
on_boot:
- priority: 600
then:
- select.set_index:
index: !lambda |-
return id(restore_mode)-1;
- lambda: |-
switch(id(restore_mode))
case 1:{
id(mini_relay).turn_off();
break;
case 2:{
id(mini_relay).turn_on();
break;
default:{
break;
esp8266:
board: esp8285
restore_from_flash: true
preferences:
flash_write_interval: 1min
api:
ota:
- platform: esphome
logger:
level: ${log_level}
baud_rate: 115200
mdns:
disabled: false
web_server:
port: 80
network:
enable_ipv6: ${ipv6_enable}
wifi:
# This spawns an AP with the device name and mac address with no password.
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.195
gateway: 192.168.1.1
subnet: 255.255.255.0
# Allow rapid re-connection to previously connect WiFi SSID, skipping scan of all SSID
fast_connect: "${wifi_fast_connect}"
# Define dns domain / suffix to add to hostname
domain: "${dns_domain}"
captive_portal:
dashboard_import:
package_import_url: github://athom-tech/athom-configs/athom-mini-switch.yaml
globals:
- id: restore_mode
type: int
restore_value: yes
initial_value: "3"
select:
name: "Power On State"
optimistic: true
options:
- Always Off
- Always On
- Restore Power Off State
on_value:
then:
- lambda: |-
id(restore_mode)=i+1;
button:
- platform: restart
entity_category: config
- platform: factory_reset
- platform: safe_mode
internal: false
output:
- platform: gpio
pin: GPIO13
light:
- platform: status_led
disabled_by_default: true
pin:
number: GPIO4
inverted: true
- platform: binary
output: relay_output
restore_mode: ${light_restore_mode}
#on_turn_on:
# - light.turn_on: led
#on_turn_off:
# - light.turn_off: led
- platform: uptime
entity_category: diagnostic
internal: true
- platform: wifi_signal
name: "WiFi Signal dB"
update_interval: 60s
entity_category: "diagnostic"
- platform: copy
source_id: wifi_signal_db
name: "WiFi Signal Percent"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "Signal %"
device_class: ""
script:
- id: hass_light_toggle
then:
if:
condition:
api.connected:
then:
- if:
condition:
light.is_off: mini_relay
then:
# Turn the relay back on and turn on the light.
- light.turn_on: mini_relay
- homeassistant.action:
action: light.turn_on
entity_id: $hass_light
else:
# Have Home Assistant toggle the light.
action: light.toggle
else:
# When HA is unavailable, toggle the relay.
- light.toggle: mini_relay
- id: hass_light_brightness
then:
if:
condition:
then:
brightness: '255'
else:
brightness: '25'
binary_sensor:
# Wired switch
- platform: gpio
pin:
number: GPIO14
mode: INPUT_PULLUP
inverted: true
#on_state:
# - light.toggle: mini_relay
on_multi_click:
- timing:
- ON for at most 0.5s
- OFF for at most 0.5s
- OFF for at least 0.1s
then:
- logger.log: "Double clicked"
- script.execute: hass_light_brightness
- timing:
- OFF for at least 0.6s
then:
- logger.log: "Single click"
- script.execute: hass_light_toggle
- timing:
then:
- button.press: Reset
# Button on mini switch
- platform: gpio
pin:
number: GPIO3
mode: INPUT_PULLUP
inverted: true
on_multi_click:
- timing:
- ON for at most 1s
- OFF for at least 0.2s
then:
- timing:
- ON for at least 4s
then:
- platform: status
text_sensor:
- platform: wifi_info
ip_address:
ssid:
mac_address:
# Creates a sensor showing when the device was last restarted
icon: mdi:clock
# device_class: timestamp
# Creates a sensor of the uptime of the device, in formatted days, hours, minutes and seconds
lambda: |-
int seconds = (id(uptime_sensor).state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
if ( days > 3650 ) {
return { "Starting up" };
} else if ( days ) {
return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
} else if ( hours ) {
return { (String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
} else if ( minutes ) {
return { (String(minutes) +"m "+ String(seconds) +"s").c_str() };
} else {
return { (String(seconds) +"s").c_str() };
icon: mdi:clock-start
time:
- platform: sntp
# Define the timezone of the device
timezone: "${timezone}"
# Change sync interval from default 5min to 6 hours (or as set in substitutions)
update_interval: ${sntp_update_interval}
# Set specific sntp servers to use
servers:
- "${sntp_server_1}"
- "${sntp_server_2}"
- "${sntp_server_3}"
# Publish the time the device was last restarted
on_time_sync:
then:
# Update last restart time, but only once.
- if:
condition:
lambda: 'return id(device_last_restart).state == "";'
then:
- text_sensor.template.publish:
state: !lambda 'return id(sntp_time).now().strftime("%a %d %b %Y - %I:%M:%S %p");'
If the light was in esphome I would try with
id(my_light).current_values.get_brightness()
but no idea how you deal with HA light.
What about creating a sensor in HA to present brightness?
