Using Loop for Timer with Multiple Climate Control devices
I am using HA to control multiple air conditioners with Coolmaster net. I have setup a timer for my climate devices and am using input slider for the Timer. So when I switch ON my climate.ac1 with Timer Slider set to 30, the climate.ac1 switches off in 30 mins.
Now as I have around 12 climate devices in my system, I want to write a generalized automation command for all climate devices so whichever climate device is switched on that particular devices should be switched off after the defined Timer period. Like if I switch on climate.ac2 HA knows that climate.ac2 should be switched off after Timer Slider Value.
Please help.
Instead of using timers, you may wish to consider using a new feature in 0.96.
You can now use a template in the for option (see documentation). Here the documentation’s example:
automation:
    platform: state
    entity_id: device_tracker.paulus, device_tracker.anne_therese
    to: 'home'
    for:
      minutes: "{{ states('input_number.lock_min')|int }}"
      seconds: "{{ states('input_number.lock_sec')|int }}"
    service: lock.lock
    entity_id: lock.my_place
Therefore you can adapt the example to turn off each AC unit based on the duration set by an input_slider. It would look something like this:
    platform: state
    entity_id: climate.AC1, climate.AC2, climate.AC3
    to: 'on'
    for:
      minutes: "{{ states('input_number.AC_minutes') | int }}"
    service: climate.turn_off
    data_template:
      entity_id: "{{ trigger.entity_id }}"
Thanks a lot, that did solve the issue.
Can I make some kind of sensor or template which displays the remaining minutes in the triggered automations. I was looking at using the timer platform with script. Something like:
timer_start:
sequence:
- service: timer.start
data_template:
entity_id: timer.AC_Timer
duration: ‚Äė00:{{ states.input_number.minutes.state | int }}:00‚Äô
But if this works it will be just 1 timer and I need it for all triggered automations.
