Using rest_command is no longer an option for Shelly Sensor in external network?
Getting data with rest_command from my two Shelly sensor (Uni & 3EM) in an external network stopped working for approx. 1 month ago.
Been working perfectly before this.
Could someone advice?
Is it related to Using rest_command is no longer an option with binary responses · Issue #118904 · home-assistant/core · GitHub?
Suggestions how to solved?
Setup in configuration.yaml
Rest:
  - resource: https://shelly-114-eu.shelly.cloud
    method: POST
    payload: 'Removed'
    headers:
      User-Agent: Home Assistant
      Content-Type: application/x-www-form-urlencoded
    scan_interval: 10
      - name: "Bjornidet Elpanna0"
        value_template: '{{ value_json.data.device_status.emeters[0].power }}'
        state_class: measurement
        unit_of_measurement: W
        device_class: power
    method: POST
    payload: 'Removed'
    headers:
    scan_interval: 10
      - name: "Bjornidet Elpanna1"
        value_template: '{{ value_json.data.device_status.emeters[1].power }}'
        device_class: power
    method: POST
    payload: 'Removed'
    headers:
    scan_interval: 10
      - name: "Bjornidet Elpanna2"
        value_template: '{{ value_json.data.device_status.emeters[2].power }}'
        device_class: power
    method: POST
    payload: 'Removed'
    headers:
    scan_interval: 10
      - name: "Framledning"
        value_template: '{{ value_json.data.device_status.ext_temperature[0].tC }}'
        unit_of_measurement: C
        device_class: temperature
    method: POST
    payload: 'Removed'
    headers:
    scan_interval: 10
      - name: "Returledning"
        value_template: '{{ value_json.data.device_status.ext_temperature[1].tC }}'
    method: POST
    payload: 'Removed'
    headers:
    scan_interval: 10
      - name: "Varmvatten efter VXLventil"
        value_template: '{{ value_json.data.device_status.ext_temperature[2].tC }}'
