Using Shelly Wall Display XL Hardware Button to change Dashboard
I have a Shelly Wall Display XL which has those four hardware button. I would like to use them to browse through different dashboards I have setup.
From what I read this could be done using the command_webview (Notification Commands | Home Assistant Companion Docs). But as Home Assistant is integrated into the Shelly UI, it is not recognised as companion app, so I cannot use this command.
Any idea on how I could browse through different dashboard when using the hardware button on the display?
Regards,
Sebastian
