Using Signal for notifications
Hello everyone,
I would like to use Signal for HA notifications (together with the companion app). I’ve read the instructions on the HA website and Github. On the Github-page I’m reading about needing to install curl on the system. I’m running HA on an x86 device.
How do I do this?
Thanks!
Ruben
Hi Ruben,
You could use the following website. You won’t have to install anything extra in HA.
It also explains right away how to make it work in HA.
Good luck. It has been working for me for a very long time.
You don’t need curl, that’s just showing you how you can test.
All you need to do is run the container (there doesn’t look to be an add-on) and set it up as the docs show.
