My system, which is LAN only, currently has a couple of older SOnOff devices, but I had to flash them with custom ROM to make them work. Needless to say, seeing that SOnOff devices can be used ‘out of the box’ is of great interest to me.
Only firmware V3+ is supported. I suspect that my new devices are V3+, correct?
I have no idea how to get the devicekey since ‘Put the device in setup mode’ in the section ‘Getting devicekey manually’ is unexplained. Can you clarify please?
I note that the S26 device has a number on the sticker on the box (starts with IMI and is under a barcode) and a number (10 digit alpha-numeric) printed on the device itself. Are either of these important?
if you use the Sonoff device’s without any firmware changes, you can also download the eWelink app on your phone. There you can see all your Sonoff device’s on your network, also see and update the firmware.
Described - yes. Very well - definitely not! The web page reads: Put the device in setup mode, but it never tells the reader how this is done. I assume that the text is referring to the SOnOff device, but again, no way of knowing.
I did some looking around and it appears that to enter setup mode, I need the IP address of the device. More reading and I found “Long click on manage button (let will start blinking fast). Look for wifi access point starting with “ITEAD-10000”.” Some further searching and I found that to see the available WiFi access points, from a Windows CMD, run ‘’netsh wlan show profiles”. I did this, but no access point starting with ITEAD. Now what??
Connect to the Wi-Fi network ITEAD-10000, password 12345678
Open in browser http://10.10.7.1/device
Copy deviceid and apikey (this is devicekey)
Connect to your Wi-Fi network and setup Sonoff via the eWeLink app
The setting mode is when the device is waiting for pairing.
It is set with the pairing button on the device.
The LED on the device flashes regularly.
I have no idea why you want to do this when, despite the classic integration of the device, it also works in a LAN network except for a few devices that need a cloud.
