Using sun elevation AND cloudiness to trigger interior and exterior lights
The {{ state_attr('sun.sun', 'elevation') }} is doing the job, but on cloudy days this value needs adjustments. {{ states.sensor.yr_cloudiness.state }} (now it’s 80,6% cloudiness).
I can use a sensor to measure the light, but I’d rather put cloudiness into account in this matter, and that is way more fun :smiley:.
How can I tweak the above: '-4.0' value via a formula/template?
This is what I want:
IF cloudy
THEN change the value of elevation to fire the trigger earlier
…since it’s darker when it’s cloudy
- platform: numeric_state
  entity_id: sun.sun
  value_template: '{{ state.attributes.elevation }}'
  above: '-4.0'
And way less accurate.
Clouds can reflect light, not just block it.
But if that is what you want, what is your cloud sensor entity_id?
Sure, but not when the sun elevation is close to the horizon. My experience, living at 60 degrees North, is that it´s darker when the sun sets and it’s cloudy, than if there are no clouds.
So
Cloudiness entity_id: sensor.yr_cloudiness, which now returns 96.1. It was more clouds earlier with value 82.6.
You will probably have to tweak the values but this should give you the general idea:
  value_template>
      {% if states('sensor.yr_cloudiness')|float < 82.6 %}
        {{ state_attr('sun.sun', 'elevation')|float > -8 }}
      {% else %}
        {{ state_attr('sun.sun', 'elevation')|float > -4 }}
      {% endif %}
Thank you, @tom_l.
So if I get this right:
IF cloudiness is less than 82.6 AND sun elevation is more than -8 THEN true
ELSE
IF sun elevation is more than -4 THEN return true
Correct?
Close enough.
