Using Synology's Surveillance Station with a Ring Video Doorbell
I have a Ring Video Doorbell and I have a Synology. I hear I could use a Surveillance Station with Ring to monitor the video feed and save recordings. How do I configure that?
Where did you hear that? As far as I know that is not possible.
This hints that it can be done - https://g.co/gemini/share/85c3a0729b8e
No, that’s AI generated garbage.
It’s not garbage. Look if you don’t want to address the question then just don’t.
The question is answered. No, you cannot use Ring cameras with Surveillance station, even if an AI says so. Ring cameras do not have support for the protocol you need to be able to do this. This is basically their business idea, you need a subscription to be able to view historic data.
Yes, it is garbage because it is telling you things that are not true.
