Using Tado thermostats in Home Assistant
Hey guys,
I bought some Tado thermostats and configured them in Home Assistant, which works well.
I just need some ideas how to use them. What do you think, should I use the Tado heating plans with manual override while windows are open? Or is it better to control the thermostats completely using Home Assistant?
Thanks for your tips.
I’m looking at greater calendar integration and awareness, over and above a simple weekly plan. Less of an issue given Covid19 when we’re all at home but if it can see school and work in the calendar then hot water is a greater priority than heating for example. WIP!
