I have this automation:
actions:
- choose:
- conditions:
- condition: state
entity_id: input_boolean.fb_bad_eg_handbetrieb
state: "on"
sequence:
- action: input_number.set_value
metadata: {}
value: >-
{{ states('input_number.fb_bad_eg_solltemperatur_handbetrieb') |
float}}
entity_id: input_number.fb_bad_eg_solltemperatur
among a LOT of other things in this automation.
I am trying to make a Blueprint out of it to assign it easily to other rooms.
However , I am unable to make it work.
I tried different approaches but nothing seems to work.
What is the correct way to read the values that I specified for inputs?
input:
handbetrieb_toggle:
name: Handbetrieb Umschalter
description: Entität des input_boolean für den Handbetrieb (z.B. input_boolean.fb_kuche_handbetrieb).
selector:
entity:
domain: input_boolean
soll_temp_handbetrieb_input:
name: Soll-Temperatur Handbetrieb
description: Entität des input_number für die Soll-Temperatur im Handbetrieb (z.B. input_number.fb_kuche_solltemperatur_handbetrieb).
selector:
entity:
domain: input_number
and
actions:
- choose:
- conditions:
- condition: state
entity_id: !input handbetrieb_toggle
state: "on"
sequence:
metadata: {}
value:"{{ states[!input soll_temp_handbetrieb_input] | float}}"
entity_id: !input soll_temp_input
i tried:
{{ states(!input soll_temp_handbetrieb_input) | float}}
Cannot Save the Automation.
{{ states('!input soll_temp_handbetrieb_input') | float}}
leads to an error when the automation is executed:
Error rendering data template: ValueError: Template error: float got invalid input ‘unknown’ when rendering template ‘{{ states(’!input solltemp_externer_sensor’) | float}}’ but no default was specified
Error rendering data template: UndefinedError: homeassistant.helpers.template.AllStates object has no element Undefined
Anyone can bump me into the right direction=
