Hi Everyone,
I want to swap the thermostat state when the weather drops below a certain point - or goes above a certain point.
I created an automation that I thought would work:
alias: Nest - Living Room - Swap Cool to Heat
description: ""
- platform: numeric_state
entity_id:
- sensor.austin_weather_realfeel_temperature
attribute: temperature
below: 60
enabled: true
- platform: device
type: turned_off
device_id: 21df3e0ce564c808c062f2c61bfb8555
entity_id: 4cf0df42d3703a2ef045aba078f3ace7
domain: switch
enabled: false
condition:
- condition: device
device_id: 68a8670c239a78168620c3a61deee72e
domain: climate
entity_id: climate.living_room
type: is_hvac_mode
hvac_mode: cool
- condition: not
conditions:
- condition: device
domain: climate
entity_id: 06ea420fc4396d34f4788d14bc6e32a1
type: is_preset_mode
preset_mode: eco
- device_id: 68a8670c239a78168620c3a61deee72e
domain: climate
type: set_hvac_mode
hvac_mode: heat
mode: single
This is my Automation YAML file (but I created it using the editor). I added a switch just to be able to test the triggering of it (that piece is disabled by default). It’s never worked, so I left it disabled.
Any ideas?
The other issue is the conditions. I can use the 3 dots to “Test” as follows:
And even when 1 fails - and the other passes, it still performs the automation (when I triggered it manually).
Any ideas?
What I am looking to do is flip the thermostat from Cool to Heat - if it’s not in Eco mode - based on the weather outside.
