Using the new CC1101 component
The CC1101 was added as a component less than a month ago and most of the posts I find here relate to the legacy external component version where you link the github (dbuezas/esphome-cc1101). Since it is no longer compatible it feels like a good time for a full rebuild.
Does anyone have a working YAML for use with the CC1101?
I have automations where if event esphome.rf_code_received is fired with code: “abcdef” then it runs this functionality works with my YAML below.
I was able to reuse some of my old YAML for the legacy variant but do not have the ability to transmit. Also the code comes in the HEX while I somehow translated it to decimal using the same lamda but that should be a minor fix.
#     CC1101 Top view
#   | 1 GND   2 VCC         -----     |
#   | 3 GDO0  4 CSN        |     |    |ANTENNA
#   | 5 SCK   6 MOSI       |     |    |ANTENNA
#   | 7 MISO  8 GDO2        -----     |
#   1 - GND  - Ground
#   2 - VCC  - 1.8v-3.6v
#   3 - GDO0 - Module Out
#   4 - CSN  - Chip Select
#   5 - SCK  - SPI Clock
#   6 - MOSI - SPI IN
#   7 - MISO - SPI Out
#   8 - GDO2 - Module Out
esphome:
  friendly_name: esp32-cc1101
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "123456789"
ota:
  - platform: esphome
    password: "123456789"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp32-Cc1101 Fallback Hotspot"
captive_portal:
spi:
  clk_pin:  GPIO14                   # D14 - Pin5
  miso_pin: GPIO12                   # D12 - Pin7
  mosi_pin: GPIO13                   # D13 - Pin6
cc1101:
  cs_pin: GPIO27                     # D27 - Pin4
  frequency: 433.92MHz
remote_transmitter:
  pin: GPIO26       # Must match GDO0     # D26 - Pin3
  carrier_duty_percent: 100%
  id: transmitter0   # Adding for ir_rf_proxy
  on_transmit:
    then:
      - cc1101.begin_tx
  on_complete:
    then:
      - cc1101.begin_rx
remote_receiver:
  pin: GPIO25      # Must match GDO2      # D25 - Pin8
  dump: all
  id: receiver0      # Adding for ir_rf_proxy
  on_rc_switch:
    then:
     - homeassistant.event:
          event: esphome.rf_code_received
            code: !lambda 'return x.code;'
# IR_RF_Proxy Testing
infrared:
  # IR transmitter instance
  - platform: ir_rf_proxy
    name: IR Proxy Transmitter
    id: ir_proxy_tx   # Corresponding ID added to remote_transmitter
    remote_transmitter_id: transmitter0
  # IR receiver instance
    name: IR Proxy Receiver
    id: ir_proxy_rx   # Corresponding ID added to remote_receiver
    remote_receiver_id: receiver0
Your yaml for cc1101 looks just ok, but you don’t have anything that transmits here.
I can’t figure out what is your approach here, but did you notice the new proxy component?
I have not seen the new proxy component that sounds like what I am looking for. My previous method was a primitive way to expose the results into Home Assistant as an “event” so it can be used in an automation.
I was able to add the IR/RF Proxy but do not see any exposed entities in home assistant. I will need to play with it more.
infrared:
    remote_transmitter_id: transmitter0 # Corresponding ID added to remote_transmitter
    remote_receiver_id: receiver0  # Corresponding ID added to remote_receiver
Shouldn’t your comment be on the remote_receiver_id line??
Agreed, updating the comment line and the original YAML to include the ID.
Played around some more and somewhat verified my “structure” against a YAML I found infrared-proxies/xiao-ir-mate/xiao-ir-mate.yaml at eedf5e349b5ea1e5d3e30ef324b78dd49fd50e5e · esphome/infrared-proxies · GitHub but have not found how to interact with it.
For the sake of completeness, I had to use copilot to help me with the transmit part. With this setup you can transmit with actions esphome.esp32_cc1101_send_rf_rcswitch or send as raw but rcswitch is much more reliable.
Event esphome.rf_code_received should still work unless I broke something but this will only show you a good rcswitch decoded message.
To the best of my understanding the proxy is not ready for use yet so this is how I interface with it.
#     CC1101 Top view
#   1 - GND  - Ground
#   6 - MOSI - SPI IN
esphome:
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
api:
  encryption:
    key: "123456789"
  actions:
    - action: send_rf_rcswitch
      variables:
        code: string
        protocol: int
        repeats: int
      then:
        - remote_transmitter.transmit_rc_switch_raw:
            code: !lambda "return code;"
            protocol: !lambda |-
              int p = protocol;
              if (p < 1) p = 1;
              if (p > 8) p = 8;
              return esphome::remote_base::RC_SWITCH_PROTOCOLS[p];
            repeat:
              times: !lambda "return repeats;"
              wait_time: 0s
    - action: send_rf_raw
      variables:
        timings: int[]
        repeats: int
      then:
        - remote_transmitter.transmit_raw:
            carrier_frequency: 0Hz
            code: !lambda |-
              esphome::remote_base::RawTimings v;
              v.reserve(timings.size());
              for (auto &x : timings) v.push_back((int32_t) x);
              return v;
            repeat:
              wait_time: 0s
ota:
  - platform: esphome
wifi:
  ap:
captive_portal:
spi:
cc1101:
remote_transmitter:
  on_transmit:
    then:
      - cc1101.begin_tx
  on_complete:
    then:
      - cc1101.begin_rx
remote_receiver:
  dump:
    - raw
    - rc_switch
  on_rc_switch:
    then:
# Webserver
#web_server:
#  port: 80
Future plans would be to migrate my WT32-ETH01 board with cc1101 over to this so I could have an ethernet based 433mhz sensor and Bluetooth proxy
ethernet:
    type: LAN8720
    mdc_pin: GPIO23
    mdio_pin: GPIO18
    clk_mode: GPIO0_IN
    phy_addr: 1
    power_pin: GPIO16
spi:
  clk_pin: GPIO14
  miso_pin: GPIO4
  mosi_pin: GPIO15
  - platform: cc1101
    cs_pin: GPIO12
    gdo0:
      number: GPIO2
      allow_other_uses: true
    gdo2:
        number: GPIO35
bluetooth_proxy:
    active: true
Hi Guys!
Looks like 27th of may still not possible to interact ir_rf_proxy..
Thanks,
Luca
could it be because of this?
Building block integration
This radio frequency is a building block integration that cannot be added to your Home Assistant directly but is used and provided by other integrations.
A building block integration differs from the typical integration that connects to a device or service. Instead, other integrations that do integrate a device or service into Home Assistant use this radio frequency building block to provide entities, services, and other functionality that you can use in your automations or dashboards.
If one of your integrations features this building block, this page documents the functionality the radio frequency building block offers.
found here: Radio frequency - Home Assistant
I guess we have to wait till this becomes somewhat usable.
JW
