Hi all,
first, thank you very much for developing the AppDaemon Addon. It’s great!
Now to my problem:
I already posted this question in the PyScript community, since I tried my python code first with PyScript und then with AppDaemon, however both show the same error.
This is related to the (unsolved) issue
https://community.home-assistant.io/t/how-to-install-pulp-package-on-appdaemon/841388.
I am trying to use the python module pulp
. Thus I configured AppDaemon to install it.
However, when I try to solve a linear programming problem with the pulp
routine solve
, using the default solver PULP_CBC_CMD
, pulp tries to execute the cbc solver in the backend, which is a command line executable usually shipped with the pulp module.
This throws the error
FileNotFoundError: [Errno 2] No such file or directory: ‘/usr/local/lib/python3.13/site-packages/pulp/apis/…/solverdir/cbc/linux/i64/cbc’
In the issue above, the conclusion was that cbc
was not installed or missing, thus I checked that in the docker container and it turns out that the executable binary exists. However executing it directly on the command line throws a similar error:
bash: ./cbc: cannot execute: required file not found
I found this on stackoverflow which could mean that some system extention/interpreter is missing.
It seems, that the problem lies in the docker container being based on alpine linux as is hinted by this issue: https_://github.com/coin-or/Cbc/issues/551. (remove underscores, as a new user I am only allowed to place two hyperlinks -.- )
Is there any method of installing the coin-or solver correctly during startup of the AppDaemon? Currently it is only possible to install apk packages, but as discussed in the issue above, there is no app package for alpine. Any other idea?
Kind regards
