Itβs a bit confusing, I know, but you need two pieces:
An add-on which uses Z-Wave JS to talk to the hardware. That can be either βZ-WaveJSβ or βZ-WaveJS UIβ. The UI version gives you the IMHO much nicer UI, and was mandatory when this guide was first written. Now, either version will work.
The ZWaveJS integration, which talks to either of the two add-ons and exposes them to the rest of Home Assistant. This is the piece youβre missing.
Uninstall the Z-Wave JS (non-UI) add-on, then take a look at the integration installation instructions, being sure to uncheck the box that installs the official add-on. The correct value for the WS URL that youβll need to finish the installation is in that part of the documentation.
Thank you so much for this blueprint! I now have 2 v2 keypads in the house, one by by each front/rear door. My wife loves using this instead of her phone to arm and change state as weβre coming and going, as well as showing status as it wakes on motion.
Only one problem I have is the first keypad upon arming Home has the audio cut off on the notification. Instead of saying βHome and Armedβ it will just give βHH-β as the voice starts to say Home. The second keypad doesnβt seem to have this problem. They are both equal distance from my zwave stick in the HA hardware so I donβt believe itβs a signal issue.
Secondly, is there a way to add some automation piece to play the βproperty 96β double-beep noise when a door is opened if the system is disarmed? Basically a notification of someone coming/going when weβre home but not armed. I am not a developer and am trying to understand how to do this with minimal knowledge.
Lastly, we use βArm Nightβ for when weβre in the master bedroom and basically want an βArmy Awayβ mode with all the motion sensors turned on but with the exception of the sensors in the bedroom weβre in. It helps us sleep knowing there isnβt motion anywhere on top of the door/window sensors.
Is there a way to configure the Police/Fire/Medical buttons as status lights for these alternate modes?
Currently the status will only show on the 3 buttons intended for Disarmed / Home / Away but it would be great to repurpose the Police light so if we add another keypad in the bedroom weβll see an accurate status displayed for the mode weβre in.
Thanks in advance if anybody finds time to help with this!
Also, there seems to be a new βlow temperature detectedβ (property: β20β) and βwater detectedβ (property: β21β) alert that flashes the keypad numbers 1, 3, 7 and 9 with the same property and command class. I havenβt been able to figure out how clear this alert without resetting the device.
Please note that I have re-interviewed the device and re-added it still with the same issues.
UPDATE: After a restart of HA it is now working correctly
I know I missing something here. I am running into a roadblock and could use some help please.
Using a v1 ring keypad, alarmo, contact sensors all connected via ZWave JS.
Have the contact sensor working and alarmo working with the keypad, my issue where i am stuck is to have the keypad light up the backlight and the ring to light up red when counting down to armed away mode. I have looked over the blueprints and installed the v2 and the v1 blueprint and i am getting the exact output in the examples (with my device showing and not the example) I just dont know what code i am missing to have the lights and sounds come out of the key pad.
