Using trigger.id as part entity id
I have a 4x4 HDMI matrix which allows me to choose any one of four inputs (Sky, Firestick, DVD or CCTV) and map it to any of four TVs. It is controlled by this interface:
which has an automation listening for changes in the input select which then runs the appropriate script to control the HDMI matrix which works fine but it is quite long winded. At the moment I have 4 trigger ids and each one has four if-then statement for example
  - choose:
      - conditions:
          - condition: trigger
            id:
              - lounge
        sequence:
          - if:
              - condition: state
                entity_id: input_select.lindy_lounge
                state: Sky
            then:
              - service: shell_command.lounge_to_sky
                data: {}
          - if:
              - condition: state
                state: Firestick
            then:
              - service: shell_command.lounge_to_firestick
                data: {}
I’d like to streamline this to something like:
  - choose:
      - conditions:
            id:
              - lounge
        sequence:
              - service: shell_command.{{trigger.id}}_to_{{states('input_select.lindy_{{trigger.id}}')|lower}}
                data: {}
However I can’t get it to work. Any ideas, please? TIA
I believe you are just missing the quotes.
  - choose:
      - conditions:
            id:
              - lounge
        sequence:
              - service: "shell_command.{{trigger.id}}_to_{{states('input_select.lindy_'~trigger.id)|lower}}"
                data: {}
Edit, noticed the second trigger is was a string
"shell_command.{{trigger.id}}_to_{{states('input_select.lindy_' + trigger.id)|lower}"
The template contains a syntax error (already identified by other users). If your goal is to streamline the automation, post it so we can examine it for other potential streamlining opportunities.
Here is the whole automation.
alias: 33. Lindy Matrix
description: ""
  - platform: state
    entity_id:
      - sensor.lindy_lounge_tv
  - platform: state
    entity_id:
      - sensor.lindy_kitchen_tv
  - platform: state
    entity_id:
      - sensor.lindy_bed3_tv
  - platform: state
    entity_id:
      - sensor.lindy_bed1_tv
  - platform: time
    at: "03:00:00"
condition: []
  - choose:
      - conditions:
            id:
              - lounge
        sequence:
          - if:
              - condition: state
                state: Sky
            then:
                data: {}
          - if:
              - condition: state
                state: Firestick
            then:
                data: {}
          - if:
              - condition: state
                state: DVD
            then:
              - service: shell_command.lounge_to_dvd
                data: {}
          - if:
              - condition: state
                state: CCTV
            then:
              - service: shell_command.lounge_to_cctv
                data: {}
      - conditions:
            id:
              - kitchen
        sequence:
          - if:
              - condition: state
                entity_id: input_select.lindy_kitchen
                state: Sky
            then:
              - service: shell_command.kitchen_to_sky
                data: {}
          - if:
              - condition: state
                state: Firestick
            then:
              - service: shell_command.kitchen_to_firestick
                data: {}
          - if:
              - condition: state
                state: CCTV
            then:
              - service: shell_command.kitchen_to_cctv
                data: {}
          - if:
              - condition: state
                state: DVD
            then:
              - service: shell_command.kitchen_to_dvd
                data: {}
      - conditions:
            id:
              - bed3
        sequence:
          - if:
              - condition: state
                entity_id: input_select.lindy_bed3
                state: Sky
            then:
              - service: shell_command.bed3_to_sky
                data: {}
          - if:
              - condition: state
                state: Firestick
            then:
              - service: shell_command.bed3_to_firestick
                data: {}
          - if:
              - condition: state
                state: DVD
            then:
              - service: shell_command.bed3_to_dvd
                data: {}
          - if:
              - condition: state
                state: CCTV
            then:
              - service: shell_command.bed3_to_cctv
                data: {}
      - conditions:
            id:
              - bed1
        sequence:
          - if:
              - condition: state
                entity_id: input_select.lindy_bed1
                state: Sky
            then:
              - service: shell_command.bed1_to_sky
                data: {}
          - if:
              - condition: state
                state: Firestick
            then:
              - service: shell_command.bed1_to_firestick
                data: {}
          - if:
              - condition: state
                state: DVD
            then:
              - service: shell_command.bed1_to_dvd
                data: {}
          - if:
              - condition: state
                state: CCTV
            then:
              - service: shell_command.bed1_to_cctv
                data: {}
      - conditions:
            id:
              - three
        sequence:
          - if:
              - condition: not
                conditions:
                  - condition: state
                    state: Sky
            then:
                data: {}
              - service: input_select.select_option
                metadata: {}
                  option: Sky
          - if:
              - condition: not
                conditions:
                  - condition: state
                    state: Sky
            then:
                data: {}
                metadata: {}
                  option: Sky
          - if:
              - condition: not
                conditions:
                  - condition: state
                    state: Sky
            then:
                data: {}
                metadata: {}
                  option: Sky
          - if:
              - condition: not
                conditions:
                  - condition: state
                    state: Sky
            then:
                data: {}
                metadata: {}
                  option: Sky
          - delay:
              hours: 0
              minutes: 0
              seconds: 10
              milliseconds: 0
          - service: switch.turn_off
              entity_id:
                - switch.lindy_hdmi_matrix
            data: {}
mode: single
i would agree that doing the "shell_command.{{trigger.id}}_to_{{states('input_select.lindy_' + trigger.id)|lower}" is probably the single biggest way to collapse this code. once you do that, i think it’ll be like 5-10 lines of action code.
Your entity names adhere to a uniform naming scheme and that feature can be leveraged to reduce the automation’s overall size (from over 200 lines to under 50 lines).
The following example is untested so it may contain errors. Let me know if you encounter any and I’ll fix them.
description: ""
  - platform: state
    entity_id:
  - platform: time
    at: "03:00:00"
condition: []
  - if: "{{ trigger.platform == 'state' }}"
    then:
      - variables:
          room: "{{ trigger.to_state.object_id.split('_')[1] }}"
          mode: "{{ states('input_select.lindy_' ~ room) | lower }}"
      - service: 'shell_command.{{ room }}_to_{{ mode }}'
    else:
      - variables:
          selects:
            - input_select.lindy_lounge
            - input_select.lindy_kitchen
            - input_select.lindy_bed1
            - input_select.lindy_bed3
      - repeat:
          for_each: >
            {{ expand(selects) | selectattr('state', 'ne', 'Sky')
              | map(attribute='entity_id') | list }}
          sequence:
            - variables:
                room: "{{ repeat.item.split('_')[-1] }}"
            - service: 'shell_command.{{ room }}_to_sky'
                option: Sky
                entity_id: 'input_select.lindy_{{ room }}'
      - delay:
          seconds: 10
          entity_id: switch.lindy_hdmi_matrix
mode: single
That’s brilliant, thank you. Also really neat demonstration of some functions that I will be able to re-use. :+1:t3:
