H,
I would like to finetune my automation.
I want to compute my availablePower differently when the wallbox is charging in ecomode.
I tried to replace with {{ availablePower }} but it will not work and I kow Why now.
So I tried to compute new energy values to change the automation later.
My main problem is, that the result of the template is not transferred to the automation. I tried tos end it in the last step but I get an empty string.
In the template esitor it shows correct values. Whats wrong?
alias: Überschussheizen Spa
description: ""
triggers:
- trigger: state
entity_id:
- input_boolean.uberschussheizbetrieb_spa
- trigger: time_pattern
minutes: /5
conditions:
- condition: state
entity_id: input_boolean.uberschussheizbetrieb_spa
state: "on"
enabled: false
- condition: state
entity_id: binary_sensor.spa_connected
state: "on"
enabled: false
- condition: state
entity_id: switch.spa_power
state: "on"
enabled: false
actions:
- variables:
availablePower: >
{% if is_state('select.wattpilot_charging_mode', 'Eco') and
is_state('input_select.vorrang_uberschussverbrauch', 'Pool') %}
{{ (states('sensor.wattpilot_charging_power') | float + states('sensor.solarnet_leistung_netzeinspeisung') | float) }}
{% else %}
{{ states('sensor.solarnet_leistung_netzeinspeisung') | float }}
{% endif %}
horst: kevin
- choose:
- conditions:
- condition: or
conditions:
- condition: and
conditions:
- condition: numeric_state
entity_id: sensor.solarnet_leistung_netzeinspeisung
above: 1900
entity_id: sensor.schalter_spa_power
below: 100
- condition: and
conditions:
above: 100
above: 105
sequence:
- action: climate.turn_on
entity_id: climate.spa_thermostat
data: {}
- conditions:
- condition: state
state: heat
sequence:
- action: climate.turn_off
data: {}
- action: notify.mobile_app_handy_nils
metadata: {}
message: Leistung "{{ availablePower }}"
mode: single
