UTC Wrong, Logbook entries have wrong date
Since recreating my VM from the latest .vmdk on the hass website, I am finding that while my configuration.yaml has the correct time zone, my logbook page always shows no entries.
On closer inspection I see the entries are there, but they are 7 hours in the past, thus out of scope for the default filters.
I ran timedateCTL on the VM and I see the UTC time is off.
Any idea how to correct this?
Thanks in advance!
lkinuxtime
From within the VM
hwclock -s
If that fails, reboot the VM I’m afraid
Thanks, tried that and have rebooted the VM many times. No effect.
Ahhh I see your hwclock is out by of sync by a significant margin.
  • Set the clock manually…
hwclock --set --date="2020-03-27 22:30:05" --localtime
  • Check both clocks are approximately in check with timedatectl. If not set your local time with date +s and hwclock -w to write local over RTC
  • Reboot to see if clocks persist
I figured it out. It was the ESXI host time. This was the culprit.
Whats strange though is that I have been running this host for 6 months now without issue, never touching that setting and yet I only ran into this problem after reinstalling from a fresh .vmdk from the hass website. go figure.
