Utility Helper units
I have created two Utility Meters Helper with three supported tariffs for ‘peak’, ‘offpeak’ and ‘standard’ tariffs. One for import and one for export. They are linked to a sensor exposed by a GivEnergyTCP integration which reports energy (i.,e. kWh).
When the helpers were created, they created three sensors each for the three tariffs. It seemed all was well.
However when I check the sensors in the Developer Tools> Statistics, although the three import sensors for the three tariffs show the unit as kWh, foe the export sensors, only the peak tariff is showing with a unit kWh. The standard and offpeak unit is not showing any unit. As such I cant add them to the Energy dashboard.
Is this because they have not detected any export during that tariff period and I need to wait or is there something else going on?
Is there a way to set the unit so I can add them to the Energy dashboard?
In configuration.yaml add
homeassistant:
  customize: !include customize.yaml
then add a file named customize.yaml and there add each missing sensor like this
sensor.blablabla:
  device_class: "energy"
  state_class: "total"
  unit_of_measurement: "kWh"
Thanks Jon for the suggestion. I did review the automation that I had created to set the export tariffs which was a copy of an import automation that sets the tariff in entity id energy_grid_octopus_flux_import, but forgot to change the target entity id. to energy_grid_octopus_flux_export.
That seems to work, but when I check the current entity states for the sensor sensor.energy_grid_export_octopus_flux_peak, when compared to the equivalent import sensor, I can see that the attributes device class and unit of measurement are missing, so I manually added them and all is fine. That is until the state changes and the attributes are removed again.
I have made a number of changes and plan to let it run for a few days (not much in the way of solar being exported at the moment) and will see if it continues to strip the device class and unit of measurement.
Well that is because you did edit it with the Developer Tools right?
If you want a permanent solution:
Thanks John. You are right I didnt appreciate that the Developer Tools would only put a temporary plaster on the problem. I have doe as suggested and created both the entry in the confiuration.yaml and created a new customize yaml file which I hope will be a more permanent fix.
But afaik, waiting until the utility meters start recording actual data should do the trick, no need to customize.
I think the problem is that I am unlikely to be exporting during offpeak. So it is not getting initiated. Anyway for now it all seems good.
