Utility Meter: Calibrate
I would like to calibrate the output from my Develco ZHEMI101 energy monitor that is slightly different to the actual reading on the utility meter it is attached to BUT when I go to “Utility Meter: Calibrate” in developer tool the drop down list does not show ant devices, I’m sure I’ve used this function in the past on another device so I can’t understand why NONE are shown
ANY suggestions greatly appreciated, I’m running the latest version of HA on a Raspberry Pi
I’m in exactly the same boat here. Is this something to do with the latest update to Utility Meter where certain things were deprecated?
Yeah something is wrong. The calibrate service is only available for tariffs but none of those are showing up for me either.
Also when I go to use the reset utility meter service only select.xxx items are available.
Open an issue here:
I can’t calibrate utility meters anymore. Reset does not even show me the entity in the list.
Calibration does set the value to 0, whatever I try to calibrate to.
Did you open a bug report?
