Utility_meter for all utilities?
All,
There is utility being the network that I would like to monitor.
I have UPNP device that has a number of sensors including in/out-going bytes/packets.
Therefore configured the following:
# Utility Meter , the modem is a Technicolor TC7210
utility_meter:
  ziggo_bin:
    #name: incoming_bspeed
    source: sensor.technicolor_tc7210_b_received
    cycle: hourly
  ziggo_bout:
    #name: outgoing_bspeed
    source: sensor.technicolor_tc7210_b_sent
    cycle: hourly
  ziggo_pin:
    #name: incoming_pspeed
    source: sensor.technicolor_tc7210_packets_received
    cycle: hourly
  ziggo_pout:
    #name: outgoing_pspeed
    source: sensor.technicolor_tc7210_packets_sent
    cycle: hourly
Then added to customize.yaml
sensor.ziggo_bin:
  state_class: measurement
  meter_period: hourly
sensor.ziggo_pin:
sensor.ziggo_pout:
sensor.ziggo_bout:
and added to a lovelace page the following entities card
type: entities
entities:
  - entity: sensor.ziggo_bin
  - entity: sensor.ziggo_bout
  - entity: sensor.ziggo_pin
  - entity: sensor.ziggo_pout
title: Ziggo network
and a statistics Graph card
type: statistics-graph
entities:
  - sensor.ziggo_bin
  - sensor.ziggo_bout
  - sensor.ziggo_pin
  - sensor.ziggo_pout
title: Ziggo Netwerk Line
chart_type: line
stat_types: []
days_to_show: 2
From the entities card I can see the newly created utilities sensors working, i.e. they are reset every hour. But the Graphics card simply does not work.
What am I missing?
Thanks Yann
you should be using sensor.technicolor_tc7210_b_received not the utility_meter ones. Set a device_class and state_class and then wait an hour and it should work.
Well,
sensor.technicolor_tc7210_packets_received has already state class total_increasing. The number of packets is always increasing (unless the modem is being reset) . I choose Unit Of Measurement is “packets” and because the customizer allows only these Device_Classes Sensor - Home Assistant and nothing like bits/bytes/packets and therefore I have choosen monetary .
AFAIK I must have an entity with state class measurement and that is what , if I understand correctly, the goal of the Utility Meter: .
But maybe I am wrong, Yann
